Go to Post 119.9999999 pounds...if only the programmers could make the code a bit lighter! - James1902 [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
Team 221 LLC
ADVERTISEMENT
Unread 01-30-2009, 08:07 AM
mminutto mminutto is offline
None #1889
mminutto is an unknown quantity at this point
Help with connecting default dashboard project
Can anyone explain step by step how to connect the Basic FRC Robot Project code to the FRC Dashboard Project code, the default projects that come with Labview? We have created and built both but we are new at this and are not sure how to connect the two, get battery data, live video feeds, etc.
Unread 01-30-2009, 09:08 AM
Dave Scheck's Avatar
Dave Scheck Dave Scheck is online now
FRC #0111 (WildStang)
Dave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond repute
Re: Help with connecting default dashboard project
Here are a few things that may get you started
- Connect the computer running the dashboard to the eth2 port of the driver station
- Make sure the IP of your computer is 10.xx.yy.6 (in your case 10.18.89.6)
- Make sure that Widows firewall is not running (for some reason I have to turn this off manually every time)
- Click the play button on the dashboard and go
Unread 01-30-2009, 02:26 PM
s0crates s0crates is offline
s0crates is on a distinguished road
dashboard project = run on the computer; robot project = on the robot.
1. deploy robot code.
2. open and run the dashboard code on the computer. No need to deploy anything in this step.
3. admire your streaming data.
4. If you want to send and output custom data, check out http://decibel.ni.com/content/docs/DOC-2978
-jonathan
Default Labview Dashboard and Windriver Example Help sircedric4 Programming 7 02-25-2009 12:58 AM
Forklift project with mecanum wheels HELP adra Technical Discussion 12 01-20-2009 11:44 PM
Urgent help with a project; brennerator Technical Discussion 3 03-05-2007 12:40 PM
need help with our default code coolguybigt Programming 14 02-19-2007 09:17 AM
help with simple project erikh98 Technical Discussion 8 08-27-2004 10:24 AM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
