Gyro Sensor
Hello. I was wondering if the gyro included in the KOP, when mounted on a turret (unfortunately off-center mounted), can return information relating to how far from dead center it currently is. I wanted to know if we could use it to get a precise measurement as to how far from neutral our turret has turned.
Thank You. |
Re: Gyro Sensor
That is not a good use for the Gyro (and off-center is a problem). Better off using a potentiometer with a large gear or something, perhaps connected to the motor moving the turret.
Re: Gyro Sensor
OK. Thanks anyway. That's actually what we're using, but I just wanted to know if there was a way to use a gyro. And one quick question. What does the gyro actually tell you? Number-wise. And if you could give a quick situational example, that would be great.
Re: Gyro Sensor
The "gyro" is actually a yaw rate sensor. Its output is a voltage that tells how rapidly it is being spun, in degrees per second. There is a characteristic voltage that represents zero spin, and a certain number of millivolts above (or below) that voltage for each degree per second it is turning.
Re: Gyro Sensor
Ok. Thank you. I understand it now.
| Gyro Sensor Questions | pheadxdll | Programming | 13 | 04-08-2008 11:52 PM |
| ADXRS150 Gyro Yaw Sensor sensitivity? | hinewwiner | Technical Discussion | 5 | 02-08-2008 08:20 AM |
| Gyro/accelerometer/Gear tooth sensor | sparrowkc | Technical Discussion | 2 | 01-11-2008 09:47 PM |
| ADXRS150 gyro yaw rate sensor | Brian M. | Electrical | 13 | 10-17-2004 01:28 AM |
| Gyro Sensor Questions | sanddrag | Electrical | 8 | 09-27-2003 07:58 PM |
