Go to Post BEING a chairmans team is alot more important then WINNING the chairmans award. - fuzzwaz [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
Kettering University
ADVERTISEMENT
Unread 02-02-2009, 07:38 PM
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Rookie Year: 2000
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
FP Gearbox: Last stage gear?
Does anyone know the DP (or module) and pressure angle of the gears in the FP gearbox's last stage (2009 model with the two blue final stages)? The pinion is a 12 teeth gear that our gear drawing software (GearTrax) can't possibly match - odd shaped teeth which does not appear to be an integer DP or usual module.
Those two old threads from very respectable sources indicate 15DP and 16DP, but the 12 teeth gear I have in my hands is a log bigger than that - I believe those gearboxes have changed a bit over the past few years.
Any gear experts over here?
Manoel Flores da Cunha
Mentor
Brazilian Machine
Team # 383
Unread 02-02-2009, 08:29 PM
kevin.li.rit's Avatar
kevin.li.rit kevin.li.rit is offline
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
kevin.li.rit is a splendid one to beholdkevin.li.rit is a splendid one to beholdkevin.li.rit is a splendid one to beholdkevin.li.rit is a splendid one to beholdkevin.li.rit is a splendid one to beholdkevin.li.rit is a splendid one to beholdkevin.li.rit is a splendid one to beholdkevin.li.rit is a splendid one to behold
Send a message via Yahoo to kevin.li.rit
Re: FP Gearbox: Last stage gear?
You can try measuring the diameter and counting the number teeth, you should be able to look up the pitch on a table at that point. I haven't opened the new fisher prices so I don't know off the top of my head.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 02-03-2009, 07:30 PM
Manoel's Avatar
Rookie Year: 2000
Well, I gave it another shot, and the best I could measure the very last gear (38 teeth, with the extended plastic) is 2.25 module, 20 degrees pressure angle (nearly perfect match). The 12 tooth gear, the one I was interested in, does not appear to be the same, by a good margin, which is obviously very weird.
Since I'm not a gear expert, not even a mechanical guy, I'll leave this one for the MEs out there. For our application, close enough was more than we needed, so we just drew the gear profile "by eye", machined it on our home-made CNC mill, measured, and iterated - only took two shots!
Mentor
Brazilian Machine
Team # 383
Unread 02-03-2009, 11:05 PM
R.C.'s Avatar
R.C. R.C. is offline
Ramping Up for the 2013 Season!
AKA: Owner, WestCoast Products & Design LLC
FRC #1323 (MadTown Robotics)
R.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond repute
Send a message via AIM to R.C.
Quick question I wanted to cnc gears on my cnc but what tools or bits would I need to get the job done?
Thanks in advance.
Unread 02-04-2009, 02:34 PM
Imaginary Friend
AKA: Kevin Li
Team Role: Student
That will depend on the size of the gear and the material. The smaller the teeth, the smaller the cutter, I assume.
Kevin Li
596 - Sciclones
Unread 02-04-2009, 03:12 PM
Justin Stiltner's Avatar
Justin Stiltner Justin Stiltner is offline
The big guy
Rookie Year: 2000
Justin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud of
Send a message via ICQ to Justin Stiltner Send a message via AIM to Justin Stiltner Send a message via MSN to Justin Stiltner Send a message via Yahoo to Justin Stiltner
Normally this requires an involute gear cutter(or hob), of which there will be several for the same Diametrical Pitch value, as the profile of the cutter needs to change a bit due to the number of teeth. You can also grind a peice of tool steel to make a form tool and use it as a single point cutter. OR if the tooth profile is large enough, you can use a properly sized end mill to cut the gear on a 3 axis mill. However this would likely be a very hard thing to accomplish(in something other than plastic / wood), for reasons I wont go into here. So, if you have a 4 axis CNC or a manual mill with a dividing head, or rotary table look into the involute gear cutters.
If you want to search around some, another word for gear cutting is hobbing.
Here is one example
http://www.youtube.com/watch?v=VHTXa...eature=related
and here is another, using a different style cutter
http://www.youtube.com/watch?v=62yme...eature=related
Justin Stiltner
Lead Robot Inspector, VCU Regional
Unmanned Systems Lab, Virginia Tech
KI4URQ
AM Planetary Gearbox (removing the fisher price gear/buying one without a gear) Ice Berg General Forum 10 02-04-2009 02:43 PM
Last Year's Gear Ratio AndyB Technical Discussion 4 11-11-2007 12:17 AM
BaneBots 56mm Gearbox - Second Stage Sun Seizing Gary Bonner Motors 18 02-10-2007 11:52 AM
Last year's gearbox MishraArtificer General Forum 3 01-10-2007 09:57 AM
Worm Gear Gearbox dddriveman Technical Discussion 38 01-07-2005 01:43 PM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
