Camera and driver station
I have searched the fourms but i have not been able to find anything. Also i have read the rules and i can not find anything. I remember reading somewhere that you could not have a live feed from your camera to your driver station. Is this true?
Thanks, 2240 Robotics *Edit: also we were thinking about using a laptop to display thine image.* Last edited by viperred396 : 02-04-2009 at 06:53 PM. Reason: added info |
Re: Camera and driver station
All communication except for the protocol between the driver station and the robot will be blocked by the routers. You can "have" a live feed being sent from the robot, but the routers will block it from ever reaching your laptop.
If you can manage to fit the image data in the rather small number of "user bytes" sent to the driver station, it's fair game. Otherwise, sorry to say, it won't really work out. |
Thanks... thats to bad our idea wont work
I remember being distinctively told that you could send video, but they're restricting the bandwidth so much that it will be useless for teams to use. |
The exact answer can be found in Team Update #5:
Out of curiosity, what needs you to be able to see through the camera, when you can just look at the field itself? Personally, I cant think of any application where i'd rather look at a microscopic image above the real thing.
There few applications where the turret operator will be better looking at the camera, or some other data you can pass on the screen with the image...
Thsnts what we are using it for ![]() |
There are a lot of cases in which the view from the alliance base can be obscured when you don't want it to be(i.e. lining up to dump into someone's trailer). Although in cases like these, its often better to just put some image processing stuff on the cRio--it's faster, and your driver isn't trying to squint at a 30x30 pixel image.
| Driver Station S.O.S. | M. Gildner | Electrical | 15 | 11-28-2009 06:35 PM |
| Driver station only regognizes USB 1 and 2 | cvxdes | Programming | 14 | 02-05-2009 01:40 PM |
| Driver Station Print | drosophyllum | Programming | 0 | 01-27-2009 08:06 PM |
| driver station and cRIO firmware update help | asianfez123 | FRC Control System | 1 | 01-16-2009 01:34 AM |
| Driver Station - Camera Feedback | sranton | Technical Discussion | 4 | 01-13-2009 11:50 AM |
