OK so i don't think I'm understanding how to program the solenoid sidecar/pneumatic bumper please help!
![]() EDIT: correction solenoid breakout Last edited by Bharat Nain : 02-04-2009 at 10:08 PM. |
Re: How to program phneumatics?
You are using the Advanced Framework correct?
Want to post the vi of what you tried to do and we can help correct it? Are you having trouble with any specific thing, such as, activating the solenoid when you pull a trigger? Last edited by Mark McLeod : 02-05-2009 at 12:24 PM. |
Correct me if I'm wrong:
The pneumatic bumper has 8 outputs, so it can drive 4 solenoids. You basically have to program the pair of outputs connected to one solenoid to have opposite states. Say you have output 0 and 1 connected to a solenoid. Output 0 is connected to the solenoid and the solenoid is connected to the piston in such a way that when output 0 is on and 1 is off, the piston extends. In that case, when output 0 is off and 1 is on, the piston would retract. There are a few examples in the examples/FRC folder that may help. |
do you mind posting links to it
Ok so i have no idea where to begin i tried the examples that i found in the programming support and it didn't work and the example in the forum pneumatics didn't work either.
Can someone please explain how i should have it wired and then please explain how if nothing else for me to press a button and the cylinder to extend? |
| How to Program a Servo | ExarKun666 | WindRiver C++ | 5 | 02-06-2009 08:05 PM |
| Advanced phneumatics | Skyman7 | NI LabVIEW | 1 | 02-05-2009 10:55 PM |
| How to conect solenoids to the circuit board. and how to program it...??? | arpitshah | Pneumatics | 6 | 01-13-2008 02:06 PM |
| How NOT to program | wun | Programming | 10 | 11-08-2004 02:34 PM |
| How to program servos | bstempi | Programming | 7 | 02-24-2004 12:45 PM |
