Go to Post Life is so much better when you do what you love rather than what others want you to do. - KelliV [more]
Unread 02-06-2009, 06:34 PM
dnrobotics11 dnrobotics11 is offline
FRC #2589
dnrobotics11 is an unknown quantity at this point
Joystick Trigger Programming
I am using WindRiver and all of the posts for the trigger programming are for LabVIEW. Could anyone help me with the programming of the buttons on the joysticks in WindRiver? Thanks a lot.
Unread 02-06-2009, 06:35 PM
FRC #2589
Re: Joystick Trigger Programming
If anyone knowns how to program limit switches that would be helpful as well. Thanks again.
Unread 02-06-2009, 07:13 PM
byteit101's Avatar
byteit101 byteit101 is offline
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
no team (The Cat Attack (Formerly))
byteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of light
Joystick stick(1);//channel 1
if (stick.GetRawButton(1-11))//1 is the trigger button, 2-11 the buttons labled as such
DigitalInput di(1);//channel 1
if (di->Get())
Bubble Wrap: programmers rewards
Watchdog.Kill();
printf("Watchdog is Dead, Celebrate!");
How to make a self aware robot: while (∞) cout<<(sqrt(-∞)/-0);
Previously FRC 451 (The Cat Attack)
Now part of the class of 2016 at WPI & helping on WPILib
Unread 02-07-2009, 12:59 PM
bwobo bwobo is offline
Team 1458
FRC #1458
bwobo is just really nicebwobo is just really nicebwobo is just really nicebwobo is just really nice
Send a message via AIM to bwobo
Is there not a GetTrigger function in Joystick.h?
I don't have the header files here, but i think there is one. (you can check)
EDIT:
in Joystick.h, there is a GetTrigger function, as well as just the normal numbered 1-11 buttons
Code:
virtual bool GetTrigger(JoystickHand hand = kRightHand);
bool GetRawButton(UINT32 button);
that is from the header file, so you would just use GetTrigger and GetRawButton
Byteit is good on the limit switch too,I think not sure, that the Jaguars also have built in limit switch support, no code required
Unread 02-07-2009, 02:26 PM
FRC #2589
Thank you all
Unread 02-07-2009, 06:10 PM
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Originally Posted by bwobo View Post
...Jaguars also have built in limit switch support,...
...which the 2009 rules do not permit using, alas.
Unread 02-09-2009, 05:52 AM
kyungjin kyungjin is offline
Software Specialist
AKA: Daniel
VRC #0646
kyungjin is an unknown quantity at this point
Send a message via AIM to kyungjin Send a message via MSN to kyungjin
You could use the GetTrigger function or use Button1 if you're using the standard joystick...
Unread 02-09-2009, 06:27 PM
csshakka csshakka is offline
FRC #0818
csshakka is an unknown quantity at this point
Send a message via AIM to csshakka Send a message via MSN to csshakka
You can use the GetTrigger() function. Something like this:
Code:
Joystick *stick;
stick = new Joystick(1);
if (stick->GetTrigger())
    // Code if trigger is held
else
    // Code if trigger is released
Buttons are similar, but you use the GetRawButton() command.
Code:
Joystick *stick;
if (stick->GetRawButton(1-11))
    // Code if button is held
else if (!stick->GetRawButton(1-11))
    // Code if button is released
Programming the joystick trigger... pudgeball C/C++ 4 01-10-2009 09:25 AM
Joystick Programming greatman05 Programming 11 01-30-2008 07:40 PM
Joystick Programming LieAfterLie Programming 7 02-15-2007 08:30 AM
Programming a Joystick sbf2009 Programming 3 02-10-2007 02:59 PM
Joystick Programming team 803 Programming 6 02-21-2006 10:49 AM
Copyright ©2000 - 2016, Jelsoft Enterprises Ltd.
