Go to Post People are human, refs are human. The refs did the best they could do at the time. - Andy Baker [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
Innovation First International, Inc.
Cross the Road Electronics
ADVERTISEMENT
Unread 02-06-2009, 11:24 PM
haxor5354 haxor5354 is offline
AKA: Jason
FRC #1558 (ACCI-DENT)
Team Role: Electrical
haxor5354 is an unknown quantity at this point
how to limit speed on the motors.
self explanatory. how to make the motors run at a limited speed with labview?
Unread 02-06-2009, 11:48 PM
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #0364 (Team Fusion)
RyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond repute
Send a message via Skype™ to RyanN
Re: how to limit speed on the motors.
Try this:
I'm not sure if it will work or not, but it certainly makes sense to me.
Controls Mentor
firstfusion364.com
Unread 02-07-2009, 06:51 AM
no team (Team NI)
I'm not sure if the question was related to joystick axis input, but that is what I'll assume.
A useful function for doing what was shown in the previous post is the In Range and Coerce function. You wire your value into the middle, and you wire your max and min in as well. You can right click on it to set whether the endpoints are included. This will work to clip your inputs.
Perhaps a better approach for the joystick is to rescale the joystickinput to a different numerical range. To do this, instead of having the joystick go from -1 to 1, perhaps you divide by 2. Not everything on the joystick is less and the joystick's full limits are only half.
Another approach that may be worth trying if you like playing with the math is to use something nonlinear. Since the joystick is in the range of -1 to 1, by squaring it, you stay in that range, but change the shape to a parabola. This will give finer control near center, but full range near the edges. You can even go crazy with the yTox function to get other shapes.
Greg McKaskle
Code to have speed of motors dependent on how hard you push the joystick JoJo5 Programming 15 02-06-2007 11:35 AM
How to speed up the dc motor via BS2? lgz108 Motors 8 11-14-2005 01:26 PM
Limit of the atwood motors? Clanat Motors 6 03-16-2004 09:46 AM
How do you set a speed limit on the servo Fares Programming 6 01-01-2003 02:04 PM
Four motors at the same speed? archiver 2001 8 06-23-2002 09:51 PM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
