HELP!!! BOOLEAN VARIABLES IN LABVIEW
Hey guys, I'm having some trouble getting limit switches working in our robot. We are using 3 Limit Switches for different positions on the Lazy Susan. We have planned out the code in notepad as follows,
Code:
//ls1 = limit switch 1 //ls2 = limit switch 2 //ls3 = limit switch 3 // 1= go left //-1 = go right boolean left = 0 boolean top = 0 boolean right = 0 if (ls1 = 1) then left = 1 end if if (ls2 = 1) then top = 1 end if if (ls3 = 1) then right = 1 end if //button 4 if (left = 1 && top = 1 && right = 0) then speed = 1 if(left = T) then top = 0; speed = 1until ls1 = 1 end if if (left = 1 && top = 0 && right = 0) then speed = 1 speed = 1 until ls1 = 1 end if if (left = 1 && top = 1 && right = 1) then speed = 1 until ls1 = 1 end if if (ls1 = 1 and left = 1) then speed = 0 end if /button 5 if (left = 1 && top = 0 && right = 0) then speed = - 1 until ls3 = 1 end if if (left = 1 && top = 1 && right = 0) then speed = - 1 until ls3 = 1 end if if (left = 1 && top = 1 && right = 1 && ls3 = 1) then speed = 0 end if /button 3 if (left = 1 && top = 0 && right = 0) then speed = 1 until ls2 = 1 end if if (left = 1 && top = 1 && right = 0) then speed = -1 until ls3 = 1 end if if (left = 1 && top = 1 && right = 1) then speed = - 1 until ls3 = 1 end if if(ls2 = 1) then speed = 0 end if Last edited by PRAWG : 02-07-2009 at 12:13 PM. |
Re: HELP!!! BOOLEAN VARIABLES IN LABVIEW
You can create a booolean variable by right-clicking on the front panel of the VI and selecting Modern and then navigating to the Boolean palette. There should be options there. An indicator/controller will appear on the backpanel.
To init the boolean, you can wire a constant to it, and then reference the boolean by local variables, (created by right-click on the object > create > local variable). The initial value will only be used when the indicator hasn't been accessed by a local variable and updated. |
For the most part, in LabVIEW, what would be variables in C are just wires between things. I don't think you need to do anything special. Just read the state of your limit switch. Its output will be a boolean value that you can wire up to the rest of your functions.
| Making global variables in LabVIEW. | Joshamuffin | National Instruments LabVIEW and Data Acquisition | 1 | 01-19-2009 12:35 PM |
| [FTC]: Variables in labview | wilsonmw04 | FIRST Tech Challenge | 2 | 11-23-2008 07:57 AM |
| Labview dashboard and multiple variables | Joe Ross | LabView and Data Acquisition | 2 | 03-15-2006 08:55 PM |
| Help figuring out controller variables | fwxer | Programming | 1 | 01-31-2005 01:28 AM |
| Need help with Variables ? | David Bryan | Programming | 5 | 02-23-2004 06:42 AM |
