Go to Post Count up all the white space in your code sometime and calculate how much weight it adds. - DeepWater [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
ADVERTISEMENT
Unread 02-10-2009, 09:47 PM
hellochar hellochar is offline
FRC #3006
hellochar is an unknown quantity at this point
accelerometer reads infinity
we've had a new problem with our accelerometers that have only recently appeared. Using labVIEW:
1) On our first run of the robot, the accelerometers will read infinity for all axes
2) We then stop the code and re-run it. This time, the accelerometers work correctly for a few reads - three to five readings - and then stops altogether. other sensors still read values
3) We then stop the code and re-run it again. This time, accelerometers work fine.
It repeats this pattern over and over again. we haven't changed any accelerometer initialization/reading code for a while, although we did have to re-sodder the PWM wires a few days ago. I would consider this to be the cause of the problem, but how would a hardware/wiring problem create a deterministic loop?
Unread 02-11-2009, 01:48 AM
dtengineering's Avatar
dtengineering dtengineering is offline
Teaching Teachers to Teach Tech
AKA: Jason Brett
FRC #1346 ("Trobotics" competed 2004-2010)
Team Role: Teacher
dtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond repute
Re: accelerometer reads infinity
Obviously this indicates that your robot has zero mass.
Sorry, I know you were looking for a more helpful answer than that. Have you tried using a multimeter to read the voltage on the accellerometer leads? That might help determine whether the problem is in the accellerometer or in the cRio software.
Jason
Unread 02-11-2009, 07:06 AM
EricVanWyk EricVanWyk is offline
Rookie Year: 2000
EricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond repute
Send a message via AIM to EricVanWyk
In addition to seconding Jason's advice, I would suggest posting your code here. It sounds to me like software.
Unread 02-11-2009, 09:10 AM
Jared341's Avatar
Jared341 Jared341 is offline
Congrats to the Champs!
AKA: Jared Russell
FRC #0341 (Miss Daisy)
Jared341 has a reputation beyond reputeJared341 has a reputation beyond reputeJared341 has a reputation beyond reputeJared341 has a reputation beyond reputeJared341 has a reputation beyond reputeJared341 has a reputation beyond reputeJared341 has a reputation beyond reputeJared341 has a reputation beyond reputeJared341 has a reputation beyond reputeJared341 has a reputation beyond reputeJared341 has a reputation beyond repute
Send a message via AIM to Jared341
Are you traveling at or near the speed of light?
What is your scaling factor or rate set to? Could there be a divide by zero somewhere?
Unread 02-11-2009, 10:09 AM
Jranko311 Jranko311 is offline
Mentor-Programmer-Design Engineer
AKA: Jon Hrenko
FRC #0155 (Technonuts)
Jranko311 is an unknown quantity at this point
Are you dividing by zero anywhere in your code?
Unread 02-11-2009, 05:26 PM
FRC #3006
Lightbulb Re: accelerometer reads infinity
haha fixed the problem. the protons were going too fast
Unread 02-11-2009, 07:47 PM
Rookie Year: 2000
Whenever you have a problem and a solution, please make an effort to post them both. This will help other teams in your position later.
Unread 02-11-2009, 08:15 PM
FRC #3006
ahh, apologies. the problem was just a low battery .. what protons?!
DS Voltage reads 00.00V lostkhaos Technical Discussion 3 01-06-2009 06:45 PM
Infinity Drive Martinez Technical Discussion 11 04-17-2007 01:00 AM
pic: Dez Reads HIGHLIGHTS! Joe Matt Chit-Chat 8 05-26-2006 10:40 AM
Who reads Slashdot? Max Lobovsky IT / Communications 31 03-26-2004 11:07 PM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
