Go to Post You can lay out all the disclaimers that you want, but the bottom line is you are representing your team. - Karthik [more]
Go Back   Chief Delphi > Technical > Programming > WindRiver C++
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
Delphi
ADVERTISEMENT
Unread 02-11-2009, 03:24 PM
FearlessLeader FearlessLeader is offline
AKA: James Wittel
FRC #2753 (Team Overdrive)
FearlessLeader is an unknown quantity at this point
Send a message via Skype™ to FearlessLeader
How to program sonar
Our Team is using the LV-MaxSonar-EZ3
We are having a lot of trouble programing for the sonar.
Can anyone post some C ++ code that uses the sonar. As far as I have seen there is no sample code for the sonar.
Thanks a lot
Team Overdrive #2753 - FRC 2008/2009
FTC 2007/2008 world champions!
New Brunswick Eruption - Future Glory Award
Attending NJ Regional
Attending NYC Regional
www.teen-technology.org
www.JPEX-studios.com
www.team-overdrive.com
Past: FTC #74, FVC #3179
Unread 02-11-2009, 09:39 PM
wt200999's Avatar
wt200999 wt200999 is offline
AKA: Will
FRC #0870 (R.I.C.E.)
wt200999 is an unknown quantity at this point
Send a message via ICQ to wt200999 Send a message via AIM to wt200999 Send a message via MSN to wt200999 Send a message via Yahoo to wt200999 Send a message via Skype™ to wt200999
Re: How to program sonar
It depends on how you have it wired. I am guessing you are using analog?
If so use the AnalogChannel class and use the AnalogChannel::GetVoltage() to get your voltage and multiply that value accordingly (a value you can find in the EZ3 datasheet)
How to program phneumatics? Skyman7 NI LabVIEW 4 02-05-2009 03:21 PM
How to conect solenoids to the circuit board. and how to program it...??? arpitshah Pneumatics 6 01-13-2008 02:06 PM
How NOT to program wun Programming 10 11-08-2004 02:34 PM
How to program servos bstempi Programming 7 02-24-2004 12:45 PM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
