| View Poll Results: Was this useful? | |||
| Yes, it was! It helped point out diamonds in the rough |
106 | 70.20% |
| No, its numbers generally did not correspond to robot's actual on-field performance |
45 | 29.80% |
| Voters: 151. You may not vote on this poll | |||
| Thread Tools |
Rating:
Display Modes |
#211
Re: Easy to use Offensive Power Rankings (OPR) program for mid-regional scouting
I have tried alamo kettering and other regionals.
I do 2012 gg predict t Then I get errors also have tried to sort it by rank it crashes then. It works if you use opr and other stuff but not predict. |
#212
Fixed! See my previous post. The problem was pretty lame (related to the new competition year), I'm going to put in something so that next year I won't forget to update things.
#213
Thanks your awesome. Also can you copy the values put of the program anyway?
#214
If you run it normally, you can right-click on the program window, choose mark, then drag-select what you want to copy and press enter. Then paste it into notepad. |
#215
Another thing I noticed is the predict doesnt work by ranking. It just still prints out the teams in their numerical order even when I type in that I want ranking.
#216
I ran the numbers for all of the regionals/districts have reported match results:
mean: 4.78140686 median: 3.803155 stdev: 6.27617293 |
#217
Looks like something I should try out. Will get back with results!
#219
Did you grab data from all of the events at once?
How? |
#220
I think if you do R instead of T for your sort order, it should work by W-L-T record. Though the predicted seed won't be accurate because teams will have coopertition points.
#222
My output is:
Its not working right.... Quote:
#223
You're right the predicted standings don't seem to work - it might be ranking using 2010's strange method rather than a normal W-L-T. Due to coopertition bridges though, I wouldn't worry about the predicted standings - they'll be completely wrong anyway since the bridge points aren't taken into account. Last edited by Bongle : 03-03-2012 at 10:23 AM. |
#225
| Offensive Power Ranking Calculations | Greg Marra | General Forum | 4 | 03-18-2009 09:03 PM |
| Offensive Power Rankings for 2008 | Bongle | General Forum | 166 | 05-18-2008 02:05 PM |
| Offensive+Defensive Power Rankings | BornaE | General Forum | 4 | 04-05-2008 12:33 AM |
| 2006 Offensive Power Ratings | sw293 | General Forum | 16 | 05-10-2006 04:04 PM |
| (CURIE) Let's make this Easy for all of us. [scouting] | 157#1Driver | Championship Event | 13 | 04-22-2002 07:56 AM |
