OCCRA   [more] Florida Regional : 110d 03h 17m ...
Go to Post I always wondered what would happen if two robots mated. - Greg Needel [more]
Team 47   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
Protobot Robot Bundles
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Delphi
ADVERTISEMENT
Old 03-16-2009, 06:39 PM
Allison Allison is offline
AKA: Allison Babcock
FRC #1024 (Kil-A-Bytes)
Allison is a splendid one to beholdAllison is a splendid one to beholdAllison is a splendid one to beholdAllison is a splendid one to beholdAllison is a splendid one to beholdAllison is a splendid one to beholdAllison is a splendid one to behold
Send a message via AIM to Allison
pic: Team 1024 Before and After
Old 03-16-2009, 06:40 PM
RMS11's Avatar
RMS11 RMS11 is offline
Safety!!!!
FRC #2415 (WiredCats)
Team Role: Driver
RMS11 is just really niceRMS11 is just really niceRMS11 is just really niceRMS11 is just really niceRMS11 is just really nice
Send a message via AIM to RMS11
Re: pic: Team 1024 Before and After
Which preformed better? What was the biggest advantage of each? Sweet looking bot both ways!
2009 Peachtree Regional Champs
2009 Palmetto Regional Champs
2008 Peachtree Rookie All Star and Rookie Highest Seed
Old 03-16-2009, 06:47 PM
Lowfategg's Avatar
Lowfategg Lowfategg is offline
Going to burn rubber in 2010.
AKA: Tyler Moser
FRC #2753 (Team Overdrive)
Lowfategg has a brilliant futureLowfategg has a brilliant futureLowfategg has a brilliant futureLowfategg has a brilliant futureLowfategg has a brilliant futureLowfategg has a brilliant futureLowfategg has a brilliant futureLowfategg has a brilliant futureLowfategg has a brilliant futureLowfategg has a brilliant futureLowfategg has a brilliant future
Send a message via AIM to Lowfategg Send a message via Skype™ to Lowfategg
Go dumpers!
Very cool looking robot.
Team Overdrive FRC #2753 - 2010
BE8 -First Seed, Winning Alliance
Ramp Riot - Attending
NJ Regional - Attending
Connecticut Regional - Attending
Questions? Just PM or AIM me.
http://team-overdrive.com/ THANK YOU NASA! GO EWCP!
Past: FTC #74, FVC #3179, FVC #73 (Driven Robotics)
Old 03-16-2009, 06:53 PM
joshsmithers's Avatar
joshsmithers joshsmithers is offline
go team 4910! get that FLL!
AKA: username-ers=myname
FRC #0587 (Hedgehogs)
Team Role: Mechanical
joshsmithers is a glorious beacon of lightjoshsmithers is a glorious beacon of lightjoshsmithers is a glorious beacon of lightjoshsmithers is a glorious beacon of lightjoshsmithers is a glorious beacon of lightjoshsmithers is a glorious beacon of light
Awesome! I see we weren't the only team to change from shooter to dumper. Rather than one hour to change over, it took us 6 hours. We were very satisfied with our new dumper. The most noticeable change was that our scoring success rate went up.
Questions: It looks like you use a spinning bar. What motor do you have turning that? Also, what is the height of the bottom of your hopper? (Ours was 45" high.)
Genius is 1 percent inspiration and 99% perspiration, which is why engineers sometimes smell really bad.
Old 03-16-2009, 06:59 PM
Meredith Novak's Avatar
Meredith Novak Meredith Novak is offline
now has 2 VEX teams in the basement
FRC #0016 (Bomb Squad)
Meredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond repute
Nice job. I was very happy to see 1024 in the hunt in Wisconsin!!!
Bomb Squad
Team 16
FIRST Hall of Fame
Kicking the Tires and Lighting the Fires since 1996
Old 03-16-2009, 07:16 PM
Thanks Meredith!
The shooter ended up ranked 28th at Midwest.
The dumper ended up ranked 6th at Wisconsin.
The advantage of the shooter was ideally that it could shooter in any direction.
The advantage of the dumper is the ability to score many balls quickly. The feed to our shooter was a bit slow so the dumper is much faster. Our dumper scored consistently while our shooter did not.
We also had issues with the camera code bogging down the driving code and creating lag at the Midwest Regional. Removal of the shooter and turret code gave our driver much more control.
We brought our dumper in as a 19 lb assembly ready to be riveted on to our hopper (matching hole pattern in both top plates). Allowing for a quick efficient change.
the bottom of our hopper is at approx 48" off the ground. Our robot as shown at Wisconsin in 59" tall. The spinning bar as you call it is a .035 Wall Aluminum tube cover in velcro, the motor running it is the banebot motor (RS-545) with a 5:1 gear box
My FIRST Resume
2003-2004 Team 1024 Student
2006-2007 Team 1747 Mentor
2008 Volunteer (Referee)
2009-??? Team 1024 Mentor
Old 03-16-2009, 07:30 PM
hillale's Avatar
hillale hillale is offline
How did I get here again?
AKA: Alec Hill
FRC #1625 (Winnovation)
hillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to behold
Send a message via AIM to hillale
I noticed the only real problem you guys seemed to have with the new design was balls seemed to get caught up in the initial intake area off of the ground. I'm glad you figured out a way to be more effective and you guys did great at Wisconsin. Do you guys know if you are going to Atlanta yet?
Old 03-16-2009, 07:58 PM
Protronie's Avatar
Protronie Protronie is offline
Have big wrench...and will use it!
Protronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud of
Send a message via ICQ to Protronie Send a message via Yahoo to Protronie
Nice job... great improvement! It's good to see 1024 back in the hunt!
-p
Protronie rule 5 - When the big wrench starts swinging, get out of the way!
Old 03-16-2009, 08:01 PM
JasonV JasonV is offline
FRC #0217 (ThunderChickens)
JasonV has much to be proud ofJasonV has much to be proud ofJasonV has much to be proud ofJasonV has much to be proud ofJasonV has much to be proud ofJasonV has much to be proud ofJasonV has much to be proud ofJasonV has much to be proud ofJasonV has much to be proud of
Send a message via AIM to JasonV
I was wondering how you were gonna change it up from midwest, and I like how the robot looks like it was meant to be built for a dumper. Nice job and good luck
Old 03-16-2009, 08:20 PM
william.walk's Avatar
william.walk william.walk is offline
william.walk is an unknown quantity at this point
The jamming problem at the intake was fixed before the elimination rounds. Beleive it or not the jaming problem at the intake of the robot (bottom) was caused by the switch from shooter to dumper. The top plate for the dumper was to flimsy and allowed the spinning brushes running the hopper to lift up. That in return allowed a set of bevel gear under the robot to seperate and the intake rollers would stop turning.
Currently we have no real plans for going to Atlanta. Basically the only way we would consider it is if we somehow win this week at Boilermaker.
We are still currently searching for something that resembles traction control with atleast a little speed for the robot. If you noticed at Wisconsin, we were slow moving and struggled greatly when put in a pushing situation.
Old 03-16-2009, 08:28 PM
Fans? If you can find the weight for it... They seem to give teams a bit of an edge.
Old 03-16-2009, 10:45 PM
Qbranch's Avatar
Qbranch Qbranch is offline
is back at Illinois.
AKA: Alex Suchko
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Do the balls feed up from the bottom to the hopper or do you have to throw them in?
Sorry, I didn't get to watch the WI webcast...
Good luck at BMR! I'll be there on Saturday.
Go Teams!
-q
2008 Championship Rockwell Automation Innovation in Control Award Winners
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Old 03-16-2009, 11:12 PM
big1boom's Avatar
big1boom big1boom is offline
Chains=Fun
AKA: Brian
FRC #2022 (The IRS(IMSA Robotics Specialists))
Rookie Year: 2007
big1boom is just really nicebig1boom is just really nicebig1boom is just really nicebig1boom is just really nicebig1boom is just really nice
The balls feed up through the entire spiral hopper, then up to a top storage area for a few balls.
Or, at least that is how I saw it at Wisconsin.
Old 03-16-2009, 11:24 PM
NorviewsVeteran's Avatar
NorviewsVeteran NorviewsVeteran is offline
Precision Driver Extraordinaire
AKA: Richard Raitt
FRC #1793 (Pilots)
NorviewsVeteran has much to be proud ofNorviewsVeteran has much to be proud ofNorviewsVeteran has much to be proud ofNorviewsVeteran has much to be proud ofNorviewsVeteran has much to be proud ofNorviewsVeteran has much to be proud ofNorviewsVeteran has much to be proud ofNorviewsVeteran has much to be proud ofNorviewsVeteran has much to be proud ofNorviewsVeteran has much to be proud of
Send a message via Skype™ to NorviewsVeteran
WHILE YOU WERE OUT: FRC
*driver comes back in the shop* .......OHMIGAWD WE HAVE A DUMPER!!!!
other team member- yes, and it only took ONE HOUR!
*driver starts crying* You guys rock... *goes over and hugs the robot*
forgive me, I am tired
______
I was in Scouts but I wanted out by the third meeting. I was in TSA, but I quit after a couple of weeks. I don't go camping with the SCA anymore. I was in taekwondo but I had to leave because I got sick.
I joined FIRST and stuck with it. It was nice enough to return the favor.
  #15   Spotlight this post!
Old 03-17-2009, 06:18 AM
Q,
They feed up through the spiral just like they did at Midwest. Once they get to the top there is poly-cord stretched between two tubes to lift the balls up in to the upper hopper. The upper hopper has poly-cord running along the bottom to move the balls forward while the top roller spins backwards to keep the balls in until it is time to dump.
Stop by on Saturday and we can give you a demo if you want.
Allison
My FIRST Resume
pic: 1024 just before first finals match at Midwest Regional Qbranch Extra Discussion 3 04-14-2008 10:20 PM
Before and After i_am_samus Games/Trivia 7 01-13-2008 10:17 AM
pic: 166 Before and After: All in Two Hours InfernoX14 Extra Discussion 3 06-30-2006 04:43 PM
pic: 1675 Before and After Kevin Kolodziej Robot Showcase 4 02-23-2005 01:22 PM
pic: Team 1595 wiring before and after!!! L@@K sgsdragons Robot Showcase 6 02-11-2005 07:25 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
