Go to Post Avoid the impulse to shoot from the hip, and find out the full picture before deciding where you stand. - gblake [more]
Unread 03-31-2009, 02:52 PM
furiousgeorge's Avatar
furiousgeorge furiousgeorge is offline
FRC #3055
furiousgeorge will become famous soon enoughfuriousgeorge will become famous soon enough
Driver's Station
is there an ideal format of how to layout the joysticks, blue box, router, and such for the driver's station so that power ports and plug-ins can easily reach the outlet
Unread 03-31-2009, 03:25 PM
Kristian Calhoun's Avatar
Kristian Calhoun Kristian Calhoun is offline
Celebrating 20 years of 25
FRC #0025 (Raider Robotix)
Kristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond repute
Send a message via AIM to Kristian Calhoun
Re: Driver's Station
The router is not needed on the field at competitions, and (IMO) joystick placement should be left to the driver's discretion. However, I would make sure to mount the Driver Station so that the competition port and Ethernet ports are easily accessible to plug in the respective cables on the field. It is highly recommended that these ports do not face your drivers - I have seen them get disconnected in the middle of a match from driver movement (which left the robot disabled for the remainder of the match). For example, our driver station is mounted an angle between the operator's and driver's controls: http://photos-h.ak.fbcdn.net/hphotos...820701_n.j pg If you do end up mounting your DS horizontally, as many teams do, just make sure that there is enough room to plug in.
Raider Robotix: Home | Twitter | Facebook | Instagram
Brunswick Eruption: Home | Twitter | Facebook
Unread 03-31-2009, 03:39 PM
heydowns's Avatar
heydowns heydowns is offline
AKA: Jeff Downs
FRC #1511 (Rolling Thunder)
heydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond repute
Do you mean on the field at FIRST events?
If so, all field connections generally come in from the driver's left when looking into the field.
The cables are also generally not long enough to reach the entire length of the station shelf, so I'd avoid putting your Driver's Station (blue box) all the way on the right of your operator's setup.
The more to the left, the easier time you'll have plugging in to it.
Also, when on the field at an event, you will not need your router that came in the kit.
Driver's station to be used at competition. Joshamuffin Control System 1 02-16-2009 10:22 AM
Driver's Station GillSt.Bernards FRC Control System 3 02-10-2009 10:12 PM
Driver's station - Consistency in construction Duncan Macdonald Technical Discussion 3 12-10-2008 04:14 PM
Inside the driver's station Jeff Rodriguez Championship Event 7 05-01-2008 09:04 PM
Need input on driver's station problem! Hawkins Control System 9 04-03-2008 09:48 AM
Copyright ©2000 - 2016, Jelsoft Enterprises Ltd.
