Go to Post It's a club if you have a bunch of people who hang out and do nothing - It's a team if all you all work together and cooperate to win. - Tytus Gerrish [more]
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Unread 04-05-2009, 06:45 AM
kyungjin kyungjin is offline
Software Specialist
AKA: Daniel
VRC #0646
kyungjin is an unknown quantity at this point
Send a message via AIM to kyungjin Send a message via MSN to kyungjin
Programming Arcade Drive
I wanted to ask the Chief Delphi community here how to implement arcade style driving using code efficiently and naturally. To clarify what I mean, I wanted to know how to program arcade style controls by individually controlling the left and right motors that are connected to the wheels (one motor controls two wheels) using an efficient coding scheme.
I know the WindRiver FRC class comes with its own Arcade Drive scheme but, for educational purpose, I tried dissecting some of the code there and couldn't find out how it works. I was hoping the CD community can help me understand just how the Arcade Drive works (I'm wondering if it's some kind of mathematical equation based on X and Y inputs of the joystick).
Thanks a lot for your help guys. I appreciate it.
- Daniel
Unread 04-05-2009, 11:14 AM
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
Re: Programming Arcade Drive
left = y_axis + x_axis
right = y_axis - x_axis
thats the simple way to do it, and you also have to limit the output
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
Unread 04-05-2009, 12:08 PM
Cadyyan Cadyyan is offline
The Button Man
FRC #1716 (Redbird Robotics)
Rookie Year: 2007
Cadyyan is an unknown quantity at this point
I don't know if you are using Jaguars but I found that if you do NOT limit your max forward speed and max reverse speed then your jaguars can blow their breakers. To fix this I just used a multiplier of 99% of the max speed. AKA:
MotorOut = Speed * .99
Watch your face!
Unread 04-06-2009, 10:02 AM
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
FRC #2423 (KwarQs), FRC #1418 (Vae Victis)
virtuald has much to be proud ofvirtuald has much to be proud ofvirtuald has much to be proud ofvirtuald has much to be proud ofvirtuald has much to be proud ofvirtuald has much to be proud ofvirtuald has much to be proud ofvirtuald has much to be proud ofvirtuald has much to be proud of
Odd. We've never had this problem.
Maintainer of RobotPy - Python for FRC
Creator of pyfrc (Robot Simulator + utilities for Python) and pynetworktables/pynetworktables2js (NetworkTables for Python & Javascript)
Team #1418 (remote mentor): 2016 Chesapeake District Champion, 2x Innovation in Control award, 2x district event winner
Team #1418: 2015 DC Regional Innovation In Control Award, #2 seed; 2014 VA Industrial Design Award; 2014 Finalists in DC & VA
Team #2423: 2012 & 2013 Boston Regional Innovation in Control Award
FRC Software Resources: http://www.virtualroadside.com/FRC/
Unread 04-06-2009, 10:28 AM
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
That's not a Jaguar issue. It'll happen if you put too much load on the circuit no matter what speed controller you use (or don't use). For example, our propeller gearing is slightly off optimum, and at full power the motors want to draw more than 40 amps. We have to throttle them back to keep from tripping the breakers. Incidentally, they are controlled by Victors.
Jaguars do have their own built-in 40-amp limit, and will shut down for several seconds if that limit is exceeded, independent of the circuit breakers.
Arcade Drive Issue and Pnuematics chenvoy NI LabVIEW 10 02-23-2009 07:03 PM
Non-Arcade Drive causes problems in Autonomous... pinballwizard96 NI LabVIEW 2 02-01-2009 07:45 PM
Arcade/Tank Drive Malfunction piedmont Programming 2 01-19-2009 04:37 PM
Arcade Drive Anfony VEX 4 11-08-2006 06:46 PM
vex programming arcade drive setting Michael Leicht FIRST Tech Challenge 3 10-17-2005 08:26 PM
Copyright ©2000 - 2016, Jelsoft Enterprises Ltd.
