Go to Post GP is a measurement that can only apply to yourself. To apply it to another is unfair to that person/group. - Andrew Schreiber [more]
Unread 10-19-2009, 06:12 PM
ferc ferc is offline
ferc is an unknown quantity at this point
Labview programming help - Deploy mode not working
Hi there,
I have a programming doubt.I deployed the simple motor program VI and it worked perfect in run or Live debugging mode. If I try to deploy it from the project explorer window it deploys the program successfully but I'm not getting the motor to run.I tried changing the value of the constant in VI to 0.1 but still it doesn't turn the motor anyways.Can you help me out with this?
Thanks and regards,
Murthy
Unread 10-19-2009, 08:33 PM
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Labview programming help - Deploy mode not working
I'm assuming you really mean the "Motor Control Example"?
I hope you set a default speed on the Front Panel before you built & deployed it. Depending on the motor 0.1 could possibly be too slow to actually cause some motors to move.
It really isn't setup to run deployed, since it requires the front panel to actually control anything and the front panel doesn't get included as part of a deployment, and isn't active when the cRIO gets rebooted.
Did you make "Motor Control Example.vi" your Startup vi when you created your build specification?
You'll find that under the Build Specification that you created -> Properties -> Source Files.
I still like to use "Run as startup" too, rather than "Deploy", just in case the "Always run deployed code at startup" wasn't checked when the cRIO was last flashed.
“It is not surprising that our common sense fails to grasp the true universe. The problem lies in assuming that our common sense represents reality.” – Michio Kaku
Unread 10-20-2009, 03:19 PM
Hello Mark!
Thanks for help.I actually didn't build the application in the first place.I'm using the simple motor control VI from Labview site.I tried building the stand-alone .exe and now when I deploy the application ,it works fine for me.
But still am quite unsure as of why the deploy from project explorer window didn't work?
Thanks,
Murthy
Unread 10-20-2009, 05:32 PM
The deploy menu item in the project is deceiving. It is there really more as a test mechanism. What you really need to do is open the VI and push the run button on the top left of the toolbar.
Greg McKaskle
Solenoids not working (programming) Parthenon Pneumatics 1 02-16-2009 11:32 AM
Deploy not working.... Help please? domoarigato Programming 17 01-24-2009 04:13 PM
Help to Deploy a Program in Labview. Delian NI LabVIEW 7 12-10-2008 08:13 PM
Activation of LabView still not working apollorest National Instruments LabVIEW and Data Acquisition 4 11-22-2008 08:09 PM
frc_camera not working but labview does Issues Programming 7 01-18-2006 06:23 PM
Copyright ©2000 - 2016, Jelsoft Enterprises Ltd.
