Go to Post Congratulations! Welcome to the hardest fun you'll ever have. - Undertones [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
Delphi
ADVERTISEMENT
Unread 10-28-2009, 11:29 PM
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
kamocat is just really nicekamocat is just really nicekamocat is just really nicekamocat is just really nicekamocat is just really nice
Send a message via AIM to kamocat Send a message via MSN to kamocat Send a message via Skype™ to kamocat
cRIO system watchdog
We have a bench test setup with a cRIO and last year's control system, excluding the driver station, to get experience with PID and motor control feedback.
The reason we're excluding the driver station is because it will be obsolete in two months, and so training people how to use it is not a good use of time.
The problem I'm running into is the PWM, Relay, and Solenoid outputs aren't functioning.
Sounds like the watchdog is dead.
However, I've opened the watchdog and "feed" it more than twice a second using the WPI "Watchdog" VIs (the timeout is .5 seconds).
Perhaps the problem is the system watchdog?
How do you make sure the system watchdog is enabled and active?
-- Marshal Horn
Unread 10-28-2009, 11:33 PM
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: cRIO system watchdog
You have to have the DS connected for the system watchdog. See http://decibel.ni.com/content/docs/DOC-2957
Unread 10-30-2009, 10:53 PM
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
Does the I/O still work if you remove the firmware image from the cRIO?
-- Marshal Horn
Watchdog!?!?!?! NC GEARS General Forum 38 01-23-2010 07:52 AM
System: Watchdog problems dboisvert WindRiver C++ 7 02-16-2009 01:36 AM
System: Watchdog problems dboisvert WindRiver C++ 1 02-15-2009 07:12 PM
purchasing buying the 2009 NI cRIO control system martin417 FRC Control System 10 12-29-2008 11:31 AM
Nearly Officially Official: cRIO Control System To Be Reused Billfred FRC Control System 64 11-02-2008 07:54 PM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
