Go to Post The urge to compete tends to drive teams to hold the ideas close during the competition season, but the urge to contribute means they get publicized afterwards. - Alan Anderson [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
Innovation First International, Inc.
Modulox
ADVERTISEMENT
  #16   Spotlight this post!
Unread 12-24-2009, 10:18 AM
TEntwistle's Avatar
TEntwistle TEntwistle is offline
AKA: Trey Entwistle
FRC #0433 (Firebirds)
TEntwistle is just really niceTEntwistle is just really niceTEntwistle is just really niceTEntwistle is just really nice
Re: 2010 Game Hint (Real)
It looks more to me like two parallel bars with stops at either end, then another set of tubes that slide over the parallel bars from one stop to the other (there is a small ledge on the pole beyond the center piece that suggests it is not really a telescoping piece)
  #17   Spotlight this post!
Unread 12-24-2009, 10:21 AM
ionave's Avatar
ionave ionave is offline
Sara Fails at Engineering
AKA: Sara
FRC #2022 (Seraphim Engineering)
ionave can only hope to improve
Send a message via AIM to ionave
Re: [BB] 2010 Game Hint #1
The mechanism in the picture looks adjustable, kind of in the same way that a hurdle can be adjusted... Maybe the robots will have the task of changing the height of the mechanism?? Who knows...
  #18   Spotlight this post!
Unread 12-24-2009, 10:22 AM
EdwardP's Avatar
EdwardP EdwardP is offline
FRC #0971 (Spartan Robotics)
Team Role: Tactician
EdwardP has a spectacular aura aboutEdwardP has a spectacular aura aboutEdwardP has a spectacular aura about
Originally Posted by Pausert View Post
I don't see how it would be adjustable. There are two pins on either sides that snap into other tubes, but those holes in the center are for attaching the plastic piece, not for sliding, right?
Perhaps the piece that slides over it just isn't pictured.
  #19   Spotlight this post!
Unread 12-24-2009, 10:23 AM
James Tonthat's Avatar
James Tonthat James Tonthat is offline
Lead Design Mentor
FRC #1477 (Texas Torque)
Rookie Year: 2007
James Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond repute
Send a message via AIM to James Tonthat
It might be a field piece, but it would have to be something attached to the robot side. Again, it just doesn't seem substantial enough (thick enough) or has proper fasteners to be a stationary (permanent) field piece.
It's shown in a horizontal position, maybe we should think of it as a vertical piece of some sort, say a tower? Maybe this is the game piece, you have to make a tower of this and use the Lexan part as some sort of shelf to hang something off of or put something on.
James Tonthat
Lead Design/Mechanical Mentor - Texas Torque - 2009-Current
james@texastorque.org
  #20   Spotlight this post!
Unread 12-24-2009, 10:25 AM
TEntwistle's Avatar
AKA: Trey Entwistle
The center (outer) poles look like they slide over the longer inner poles and stop at the pins at either end. On the render, there is a little ledge on the poles that suggests that the inner pole extends the entire length of the image, and that the larger diameter pole is actually shorter than at first glance. I still don't ahve a clue as to what it does, though.
  #21   Spotlight this post!
Unread 12-24-2009, 10:27 AM
AcesJames's Avatar
AcesJames AcesJames is offline
Division by Shaker
AKA: James Temple
FRC #0229 (Division By Zero)(EWCP)
Team Role: Coach
AcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond repute
Send a message via AIM to AcesJames Send a message via MSN to AcesJames Send a message via Skype™ to AcesJames
Perhaps we should think of what someone might call this object, rather than what it's function is? A name for this piece might be some kind of play on words for a more complex and subtle game hint within this piece itself. I mean....it is the GDC we're dealing with here...
Student - FRC 176 Aces High (08 - 12)
Mentor - FRC 229 Division By Zero (12 - ??)
Clarkson University - 2016, B.S. Aeronautical Engineering
  #22   Spotlight this post!
Billfred's Avatar
Billfred Billfred is offline
Next Year Starts Now
AKA: @WmLeverette, @LosPollosLocos, @SCRIW...
FRC #2815 (Los Pollos Locos)
Send a message via AIM to Billfred
You're right about the tubing diameters, but I don't think the bigger ones slide on the smaller ones out to the stops. (Where would those two fasteners slide in the absence of slots in the smaller tube?)
William "Billfred" Leverette - Gamecock/Jessica Boucher victim/Facebook-er
Billfred's World Tour: USC Kickoff Palmetto CMP Robot Rodeo Manchester Kickoff Florida Palmetto CMP Capital Clash USC Kickoff FVC Orangeburg Florida Peachtree Palmetto CMP Mission Mayhem Exploding Bacon Vex Event Duel on the Delaware CalGames USC Kickoff Florida Chesapeake Palmetto CMP BattleCry Mission Mayhem Brunswick Eruption 6 Clemson Kickoff Chesapeake Palmetto CMP IRI TNT Greenville Tech Scrimmage Bayou Palmetto CMP IRI GRITS TNT Bayou Palmetto CMP IRI Citadel Kickoff Peachtree Palmetto CMP IRI TNT SCRIW Citadel Kickoff Peachtree Palmetto Championship IRI SCRIW II Chapin Kickoff Palmetto South Florida (43,212.5 miles)
Season number 10. Still on a mission from Bob.
  #23   Spotlight this post!
Unread 12-24-2009, 10:29 AM
gallo26's Avatar
gallo26 gallo26 is offline
Team 79 Alumni
AKA: Bryan Gallo
FRC #0079 (Team KRUNCH)
Rookie Year: 2007
gallo26 is a name known to allgallo26 is a name known to allgallo26 is a name known to allgallo26 is a name known to allgallo26 is a name known to allgallo26 is a name known to all
Send a message via AIM to gallo26 Send a message via Skype™ to gallo26
FIRST did this in 2008 with the Overpass. They weld it together, and pretty much make it a connection. So maybe this piece is solid and doesnt move, but what it's connected to....
Team 79 Alumni '11- Present
Team 79 Driver '09, '10
Team 79 Senior CAD Designer '09, '10
Team 79 President '09
Team 79 Electrical Sub Team Leader '08, '09
  #24   Spotlight this post!
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is offline
Mad Scientist
AKA: Me
FRC #1729 (Plan B)
Daniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond repute
Send a message via MSN to Daniel_LaFleur
Originally Posted by brianc217 View Post
This is the first actual hint released today on Bill's Blog and the usfirst.org website.
Looks to me that it's in the wrong orientation and that it is a support for something like a 2x4 or box aluminum.
___________________
"We are not now that strength which in old days moved earth and heaven; that which we are, we are;
One equal temper of heroic hearts, Made weak by time and fate, but strong in will
To strive, to seek, to find, and not to yield. "
- Tennyson, Ulysses
  #25   Spotlight this post!
Unread 12-24-2009, 10:34 AM
Boydean's Avatar
Boydean Boydean is offline
AKA: Brandon Dean
no team (TBA)
Boydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant future
Send a message via AIM to Boydean Send a message via Skype™ to Boydean
I say they are lasers, and you have targets you have to shoot. The field is foggy too. There are some safety issues involved, but he I can dream right?
(Wow I'm posting this on my blackberry curve in a waffle house)
  #26   Spotlight this post!
Unread 12-24-2009, 10:35 AM
TEntwistle's Avatar
AKA: Trey Entwistle
Good point. I don't think that the connectors go all the way through, though. If they only went in to the outer tube, without penetrating the other side, you wouldn't need the slots, but you also wouldn't ahve a very strong connection either.
The center bracket has 4 small holes in it, making me think that they are designed to be attached to a very specific piece, not used as a rest or anything else. I can't think of anything that would fit that bolt pattern. Perhaps a gearbox, or some other item that we regularly use, but with a bolt pattern that is new from prior years.
  #27   Spotlight this post!
Unread 12-24-2009, 10:36 AM
David Brinza's Avatar
David Brinza David Brinza is offline
Lead Mentor, Robot Inspector
FRC #0980 (ThunderBots)
David Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond repute
Perhaps a mod can merge the threads?
"There's never enough time to do it right, but always time to do it over."
2003 AZ: Semifinals, Motorola Quality; SoCal: Qtr-finals, Xerox Creativity; IRI : Qtr-finals
2004 AZ: Semifinals, GM Industrial Design; SoCall: Winners, Leadership in Controls; Championship: Galileo #2 seed, Quarterfinalist; IRI: Champions
2005 AZ: #1 Seed, Xerox Creativity; SoCal: Finalist, RadioShack Controls; SVR: Winners, Delphi "Driving Tomorrow's Technologies"; Championship: Archimedes Semifinals; IRI: Finalist
2007 LA: Finalist; San Diego: Q-finals; CalGames: Finalist
2008 San Diego: Qtr-finalist; LA: Winners; CalGames: Finalist
2009 LA: Semifinals; Las Vegas: Qtr-finalist; IRI: #1 Seed, Finalist
2010 AZ: Motorola Quality; LA: Finalist
2011 SD: Qtr-finalist; LA: Qtr-finalist
2013 LA: Xerox Creativity, WFFA, Dean's List Finalist
  #28   Spotlight this post!
Unread 12-24-2009, 10:41 AM
s_forbes's Avatar
s_forbes s_forbes is offline
<-- Safety first!
FRC #0842 (Falcon Robotics)
s_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond repute
Possibly a field element for dispensing game pieces? Looks to be about 8" wide, assuming that's 1/4" polycarbonate. Maybe a clue as to how big/how many game pieces we have this year?
Better yet: a tray that holds one robot's battery at the beginning of the match. In order to be functional, an alliance member must go get the battery and plug in the disabled robot.
- Steven Forbes
2006-2010: NERDS..........1726
2010: Turbulence............3194
2011-?: Falcon Robotics...842
Check out "Babs" the underwater robot --- and some neat robot videos
  #29   Spotlight this post!
Unread 12-24-2009, 10:45 AM
TEntwistle's Avatar
AKA: Trey Entwistle
An additional thought - the holes in the inner side of the outer tubes looks like they are there so that the bolts holding the brackets to the poles can be tightened or a nut placed on them. It sounds crazy, but if the machine screw were placed from the inner aspect of the pole (using the access hole), if the screw hear were slightly rounded to match the internal diameter of the tube, and if the hole in the outer tube were countersunk (countersinked?), the connection could still be secure, yet allow the outer pole to slide over the inner.
I like the idea of the bracket connecting to a 2x4 or aluminum box. Perhaps it creates a field element that raises adn lowers, giving the robots a short windoe of opportunity to cross from one side of the field to the other, like the year that the robots had to cross on the tilting platform.
  #30   Spotlight this post!
Unread 12-24-2009, 10:48 AM
gallo26's Avatar
Team 79 Alumni
AKA: Bryan Gallo
Rookie Year: 2007
It looks like there are short standoffs?
2003 Stack Attack had the same thing. If your robot was small enough, you could just go right under
2010 Game Hint (Real) rtfgnow Rumor Mill 8 12-24-2009 10:36 AM
[Joke] 2010 Game Hint Greg Needel Rumor Mill 67 12-24-2009 09:30 AM
Game Hint #3 SuperJake General Forum 1 12-29-2008 01:59 PM
Game hint #3 garyk General Forum 7 01-02-2008 03:54 PM
Game hint?!?! Andy Grady Rumor Mill 67 12-30-2002 05:15 PM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
