Go to Post FIRST is, of course, a grand social experiment in American culture - jonathan lall [more]
Go Back   Chief Delphi > Technical > Programming > WindRiver C++
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
ADVERTISEMENT
Unread 01-14-2010, 07:55 PM
mandalorethx mandalorethx is offline
FRC #0272
mandalorethx is an unknown quantity at this point
Cannot Download Code
We are using Windriver for C++ development on the robot and I cannot download code to the robot. the cRIO is updated to c-2010_v19 and I have also applied the latest updates to windriver. at this point we are only trying to load example code (DefaultRobot).
IP addresses are correctly assigned and the FIRST downloading preferences are set
I can get the remote registry to connect to the robot, but when I go to FIRST > Download the downloading window comes up and reports that it is downloading code, but the status bar does not come up, it will sit there for a while, but will not download code.
Thank you for any advice you can give.
Unread 01-14-2010, 07:56 PM
FRC #0272
Re: Cannot Download Code
Also, I get the following error across a serial cable at the end of the booting process of the cRIO:
NI-VISA Server 4.5 started successfully.
task 0xe41130 (t1) deleted: errno=1835009 (0x1c0001) status=1 (0x1)
Unread 01-15-2010, 02:08 AM
ranc ranc is offline
FRC #2489
ranc is an unknown quantity at this point
try disabling any firewalls you have
Unread 01-15-2010, 10:01 AM
BradAMiller BradAMiller is offline
AKA: Brad
#0190 ( Gompei and the Herd)
BradAMiller has much to be proud ofBradAMiller has much to be proud ofBradAMiller has much to be proud ofBradAMiller has much to be proud ofBradAMiller has much to be proud ofBradAMiller has much to be proud ofBradAMiller has much to be proud ofBradAMiller has much to be proud ofBradAMiller has much to be proud of
Just to be sure... you are downloading the ProjectFile.out file in the downloader preferences... Then the program should start on reboot of the cRIO and not when you download it.
Brad Miller
Robotics Resource Center
Worcester Polytechnic Institute
Unread 01-15-2010, 11:35 AM
ZP8892's Avatar
ZP8892 ZP8892 is offline
FRC #0369
ZP8892 is an unknown quantity at this point
Send a message via AIM to ZP8892
Exclamation Re: Cannot Download Code
Does anyone know the setup required to download a code to cRIO? I am having issues figuring that out. Any help would be greatly appreciated.
Unread 01-15-2010, 11:44 AM
heydowns's Avatar
heydowns heydowns is offline
FRC #1511 (Rolling Thunder)
heydowns is a name known to allheydowns is a name known to allheydowns is a name known to allheydowns is a name known to allheydowns is a name known to allheydowns is a name known to all
Complete instructions are in the C++ getting started guide:
http://first.wpi.edu/Images/CMS/Firs...artedWithC.pdf
Cannot get Code to Download to cRIO greekgod8591 WindRiver C++ 25 03-09-2009 09:10 PM
Cannot Download Code to our Robot jcvd WindRiver C++ 9 01-27-2009 12:09 PM
Can't Download Code nickmagus Programming 1 01-05-2009 04:52 PM
2006 Robot Code Download Chris_Elston easyC for FRC 2 05-05-2006 09:42 AM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
