Go to Post People don't have to "get" it. They just have to know about it. Once they know about it, then they come to it, experience it, talk to it, learn it, then get it. - Taylor [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
Delphi
ADVERTISEMENT
Unread 01-14-2010, 08:16 PM
NinJA999's Avatar
NinJA999 NinJA999 is offline
Chipmunk NinJA
AKA: Nick Aldwin
FRC #0811 (Team 811)
NinJA999 will become famous soon enough
Send a message via AIM to NinJA999 Send a message via Skype™ to NinJA999
Wait Exception?
We've been porting some of our code from last year into Java. We tried to execute a wait command, but first we had to wrap it in a try catch statement. It catches the exception with the message:
"current thread (first.team811.game2010.Team811Robot - main (pri=5)]) not owner (null)"
Is there a way we can utilize wait in Java?
Team 811 (Nashua, NH) - Mentor
Previously Team Lead & Programming Lead
Unread 01-15-2010, 07:35 AM
derekwhite's Avatar
derekwhite derekwhite is offline
Java Virtual Machine Hacker
no team (FIRST@Oracle)
derekwhite is on a distinguished road
Re: Wait Exception?
You didn't post your code, but the likely problem is that in Java you need to lock your object before doing a wait() or notify() on it. The Java wait() will unlock the object, wait until it receives a notify, then relock the object.
You can find some details on this in the Java Tutorial:
http://java.sun.com/docs/books/tutor...guardmeth.html
Unread 01-15-2010, 10:21 AM
BradAMiller BradAMiller is offline
AKA: Brad
#0190 ( Gompei and the Herd)
BradAMiller has much to be proud ofBradAMiller has much to be proud ofBradAMiller has much to be proud ofBradAMiller has much to be proud ofBradAMiller has much to be proud ofBradAMiller has much to be proud ofBradAMiller has much to be proud ofBradAMiller has much to be proud ofBradAMiller has much to be proud of
Re: Wait Exception?
Instead of using Wait() you need to use Timer.delay(). The problem with Wait is that is a method on the Object class which is the base for all objects. So using wait doesn't really work.
First, be sure you have this import:
Code:
import edu.wpi.first.wpilibj.Timer;
Then, here is an example of using delay:
Code:
    public void autonomous() {
        System.out.println("In autonomous");
        for (int i = 0; i < 40; i++) {
            drivetrain.drive(1, 0.0);
            Timer.delay(2); // wait 2 seconds
            drivetrain.drive(-1, 0);
            Timer.delay(2);
        drivetrain.drive(0.0, 0.0); // drive 0% forward, 0% turn (stop)
Brad Miller
Robotics Resource Center
Worcester Polytechnic Institute
Unread 01-15-2010, 01:13 PM
NinJA999's Avatar
Chipmunk NinJA
AKA: Nick Aldwin
Re: Wait Exception?
Great, thanks!
Exception in Timer.cpp Phazonmutant WindRiver C++ 2 02-17-2009 08:27 AM
Target Exception - Exception in Kernal Task Thxe WindRiver C++ 3 02-10-2009 06:24 AM
error - language-plug-in exception... RedOctober45 Programming 1 01-16-2008 02:54 PM
Joystick Exception? Blair Frank IFI Control System 3 02-09-2007 09:41 PM
Can't wait Rabid Robots OCCRA 0 11-15-2002 09:36 PM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
