Go to Post When I first read this comic, I thought "Awww, how cute!". But then, thoughts of Karthik singing J. Lo's "Love Don't Cost a Thing" started running around through my head, and everything changed. - Travis Hoffman [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
Team 221 LLC
ADVERTISEMENT
Unread 01-16-2010, 01:59 PM
railerobotics's Avatar
railerobotics railerobotics is offline
FRC #0935
railerobotics is on a distinguished road
Run dashboard on development computer
Is it possible to run the dashboard on the development computer? If so, how would we go about doing it?
Inspiration of Today,
Technology of Tomorrow.
Team 935
http://www.team935.com
Unread 01-16-2010, 03:59 PM
no team (Team NI)
Re: Run dashboard on development computer
To run the dashboard on a development computer, but the driver station on the Classmate, you navigate to the setup tab on the DS and set the dashboard to be remote and enter in the IP of the development computer. At that point, the DS will forward packets to that IP/port. It is up to you to put the dashboard on the development computer and to start it.
Greg McKaskle
Unread 01-16-2010, 10:26 PM
umangv620 umangv620 is offline
Programming Captain
AKA: Umang
FRC #1403 (Cougar Robotics)
umangv620 will become famous soon enoughumangv620 will become famous soon enough
Go into c:\Program Files\ and copy the FRC Dashboard and FRC DriverStation folders onto a USB and copy them back on another computer.
Unread 01-17-2010, 07:15 AM
no team (Team NI)
Note that copying around executables will work fine as long as the other computer has a LabVIEW runtime engine and other driver files installed on the other computer. If it doesn't work, use the driver station installer, then copy over the EXEs.
Greg McKaskle
Unread 01-17-2010, 09:22 AM
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Since the driver station installer installs the dashboard, it shouldn't be necessary to copy any executables.
Unread 01-26-2010, 08:18 AM
ligerbots ligerbots is offline
AKA: Elie GLik
FRC #2877 (Ligerbots)
ligerbots is an unknown quantity at this point
Send a message via AIM to ligerbots Send a message via Skype™ to ligerbots
is the driver station install "DSUpdate1.0for2010.zip"? Because I ran that on my Dell development laptop and now do not see the directory FRC Dashboard in program files. Should I just copy the folder from the provided laptop?
Also could I just plug in my laptop with the driver station into the router and use that without setting the ip's.
Thanks!
Unread 01-26-2010, 08:24 PM
Patrickwhite's Avatar
Patrickwhite Patrickwhite is offline
May the North be with you
FRC #0610 (The Coyotes)
Patrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of lightPatrickwhite is a glorious beacon of light
The Dashboard is contained in a separate update, FRCLabVIEWUpdate2.0for2010.zip.
You could just plug in the driver station laptop without doing anything to change IP's, but you probably wouldn't be able to connect. With the driver station's default settings, the IP will be automatically changed, so it's in your interest to use the 'remote' setting.
Computer Science or Computer Engineering? KRibordy College & University Education 14 10-09-2009 12:56 AM
Robot Run 5K Run/Walk - fundraise or come for the fun Carol Fundraising 0 03-06-2009 03:14 PM
Development on OS X Validius Programming 22 04-19-2008 01:33 AM
Labview Dashboard and updated IFI dashboard spec Joe Ross LabView and Data Acquisition 1 04-04-2006 01:04 AM
Can I run the code on a computer? Anton Programming 1 02-06-2005 04:24 AM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
