Go to Post I have photos of students working the lathe dressed for a concert! Makes me wish for a formal dress night at robotics. - Mark McLeod [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
Innovation First International, Inc.
Kettering University
ADVERTISEMENT
Unread 10-08-2001, 09:01 AM
Dennis Hughes Dennis Hughes is offline
#0027 (Team Rush)
Dennis Hughes is on a distinguished road
Drill motor gearBox question
Does anyone now the actual stepped gear reduction ratio for the drill motor gearbox? I know the gearbox in high is approx. 20:1 and in low is approx 64:1. I'm looking for the actual gear ratio for each stage,(gearbox has 3 stages), in high gear as well as low?
I figured I would ask the community before I go through the trouble of cracking open a gearbox.
Unread 10-08-2001, 12:18 PM
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is online now
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Rookie Year: 2000
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
Hello Dennis
You might also look through the FIRST handbook. They might list the ratios for the gearbox. I know it lists the speed and torque of the various motors we use from the kit.
Hope this helps.
Wayne Doenges
We Build Robot and Careers
2012 BMR #7th seed, Winners Thanks to FRC Team 1756 and FRC Team 4028, UL Safety Award and GM Industrial Design Award
2010 BMR #1 Seed, UL Safety Award (Threepeat), Engineering Excellence Award, Quarter finals. CT Regional, Entrepreneur Award, Finalists
2009 Boilermaker, Quarter Finals, Imagery and Safety. (second time) Awards. IRI, Outstanding Quality. CAGE, Best feature and winners
Unread 10-08-2001, 01:53 PM
ChrisH
Posts: n/a
Dennis,
You might as well just crack one open. The drill motor gearboxes are 3 stage planetary gears. The gear ratio depends on which stages are locked. Though as I recall all of the stages use the same gears.
A good mechanical engineering reference book like the Lindberg PE exam book or "Mechanical Engineering Design" by Shigley will have the formulas for the effective gear ratio if you have the numbers of teeth.
Actually, taking one apart would be a good educational exercise. Putting one back together is even more of one. Last year we had to do this several times to rebuild gearboxes when we broke components. Once you learn how it's not a big deal.
I'd tell you how, but I don't remember off hand and the nearest gearbox I know of is several miles away...
Chris
Unread 10-10-2001, 09:00 AM
Paul Copioli's Avatar Unsung FIRST Hero Woodie Flowers Award
Paul Copioli Paul Copioli is offline
President, VEX Robotics
FRC #0217 (ThunderChickens)
Rookie Year: 2000
Paul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond repute
planetary gear ratios
Dennis,
For each planetary set, the gear ratio can be calculated as follows:
1. the small gear in the middle is the sun gear, the internal gear (the one with the teeth on the inside also called the fixed gear) is called the ring gear.
2. the gear ratio for each stage is calculated as folows:
# of teeth on ring gear
------------------------------ + 1
# of teeth on sun gear
3. Multiply each stage's gear ratio together to get the total ratio. If in high speed, the second stage gear ratio is 1; so only multply the 1st and the 3rd stages.
-Paul
Unread 10-11-2001, 06:11 AM
#0027 (Team Rush)
Thanks Paul !!
If anyone is interested, this is what I calculated:
Planetary gear train stage 1: (motor gear as the sun gear)
Ratio= 4.5:1
Planetary gear train stage 2:
Ratio= 3.2:1
Planetary gear train stage 3:
Ratio= 4.3:1
Looks like it correlates to the published overall gearbox ratio's I've see and used in the past of 64:1 (Low) and 20:1 (High)
Thanks Again
Portable cordless drill press Gui Cavalcanti Technical Discussion 25 08-03-2003 09:21 PM
drill motor mounts- again Jeff Sharpe Motors 6 04-07-2003 10:20 PM
Emergency drill trade/sell Anarkissed General Forum 3 02-16-2003 09:37 PM
Q&A Discuss: HOT drill motors CD47-Bot Extra Discussion 1 01-27-2003 12:31 PM
"Motors and Drive train edition" of Fresh From the Forum Ken Leung Bulletins and Newsletters 6 01-29-2002 11:32 AM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
