Go to Post Everyone knows the best way to lose weight is to turn the robot upside down, shake vigourously, and throw away anything that falls out. - Mark Hamilton [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
ITT Tech
ADVERTISEMENT
Unread 01-21-2010, 03:46 PM
Jason F Jason F is offline
FRC #2198
Jason F is an unknown quantity at this point
How to program solenoid and compressor?
Hi, this is team 2198 and we are having trouble programming for the solenoids and compressors for java. We would appreciate any help we can receive whether it is a program or a simple guide.
Thanks for reading
Unread 01-21-2010, 08:56 PM
derekwhite's Avatar
derekwhite derekwhite is offline
Java Virtual Machine Hacker
no team (FIRST@Oracle)
derekwhite is on a distinguished road
Re: How to program solenoid and compressor?
If someone has real sample code, jump in. In the mean time, there is some test code in edu.wpi.first.wpilibj.CompressorTest which is used to test WPILibJ on a special test rig.
Also, if you could give some details about the problems your seeing?
- not sure how to get started?
- code doesn't compile?
- code runs with exceptions?
- code runs, but doesn't do what you want?
Unread 01-22-2010, 08:51 AM
FRC #2198
I am not sure howto get started
Unread 01-22-2010, 10:40 AM
derekwhite's Avatar
OK, there's some solenoid example code in the DefaultCodeProject.
From NetBeans, select "File/New Project...". In the window, open the "Samples" folder, select "FRC Java", then "DefaultCodeProject.zip" and continue making the project from there.
Also, as I mentioned before there is some test code in WPILibJ. To see that code, select "File/Open Project...". Navigate to your "sunspotfrcsdk" directory, then the "lib" directory under that. From there select WPILibJ.
Unread 01-29-2010, 11:51 PM
Derschatten Derschatten is offline
FRC #1203 (Pandemonium)
Derschatten is an unknown quantity at this point
This should give you a good idea.
Code:
package edu.wpi.first.wpilibj.templates;
import edu.wpi.first.wpilibj.Compressor;
import edu.wpi.first.wpilibj.Solenoid;
public class Airsystem extends SimpleRobot {
     private Joystick DriverStick;
     private AxisCamera camera;                       //defines Axis Camera
     private Solenoid s1,s2;                             //defines solenoids
     public Airsystem() {
          DriverStick = new Joystick(1);             // USB port
          airCompressor = new Compressor(1,1);  //Digtial I/O,Relay
          airCompressor.start();                        // Start the air compressor
          s1 = new Solenoid(1);                        // Solenoid port
          s2 = new Solenoid(2);
     public void autonomous() {
     public void operatorControl() {
          if(DriverStick.getRawButton(1) == true)
                s1.set(true);
                s2.set(false);
           if(DriverStick.getRawButton(2) == true)
                s1.set(false);
                s2.set(true);
Unread 01-30-2010, 03:37 PM
bamse bamse is offline
UFO Designer
AKA: Fredrik
FRC #2745 (Some Assembly Required)
bamse is an unknown quantity at this point
Thumbs down Re: How to program solenoid and compressor?
Howdy...
We had to insert this piece of code in the operatorControl() as well,
// New compressor code...
if (airCompressor.getPressureSwitchValue()) {
airCompressor.setRelayValue(edu.wpi.first.wpilibj. Relay.Value.kOff);
} else {
airCompressor.setRelayValue(edu.wpi.first.wpilibj. Relay.Value.kOn);
And don't forget to turn the compressor off when exiting your operatorControl loop...
Unread 02-07-2010, 12:00 AM
Kingofl337's Avatar
Kingofl337 Kingofl337 is offline
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Rookie Year: 1998
Kingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond repute
Send a message via Yahoo to Kingofl337
Originally Posted by bamse View Post
Howdy...
} else {
This is not correct, call the Compressor class tell it the digital input and the spike port and it will take care for you.
ex: Compressor myComp = new Compressor(1,1); //That's all you need
Intelitek Support
[BFIRST Team 146 Blue Lightning - Alumni[/b]
FIRST Team 40 Checkmate
Unread 02-07-2010, 12:22 AM
MattD's Avatar
MattD MattD is offline
AKA: Matthew Douglas
FRC #0228 (GUS Robotics)
MattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to behold
Send a message via AIM to MattD
By default, the compressor is not enabled until you call the start() method on it. This is needed in addition to the creation of a Compressor object.
Howdy...
} else {
Make sure to call start() on the compressor object, and also make sure that it is a class member so it does not go out of scope. Since the example code in post #5 shows no declaration for airCompressor, my best guess is that you're creating a new one each loop.
The example should look more like this:
Code:
     private Compressor airCompressor;
GUS Robotics Team 228
2010 WPI Engineering Inspiration Award
2010 WPI Regional Champions (Thanks 230 & 20!)
2010 CT VEX Champions
2010 CT VEX Innovate Award
2009 QCC VEX Champions
2009 CT Motorola Quality Award
2007 CT J&J Sportsmanship Award
2006 CT Best Website Award
Unread 02-08-2010, 02:15 PM
synth3tk's Avatar
synth3tk synth3tk is offline
The Voice
AKA: David Thomas
Rookie Year: 2007
synth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond repute
Send a message via Skype™ to synth3tk
Instead of deleting your post with "Problem is now solved", can you please tell us in case we have the same issue? We also don't know how to program the compressor using Java.
The difference between theory and application is that in theory, theory and application are the same; In application, they are not.
Solenoid Wiring and Compressor Help BurtGummer Electrical 16 02-17-2010 01:25 PM
How do you download a program and have it saved to the c-rio 2560DawgDM NI LabVIEW 12 02-03-2010 07:58 PM
How to download and keep a program on crio zackcool123 Programming 2 02-16-2009 05:22 PM
How to conect solenoids to the circuit board. and how to program it...??? arpitshah Pneumatics 6 01-13-2008 02:06 PM
Teach Genia How to Program and Win a Prize Eugenia Gabrielov Chit-Chat 25 02-25-2005 12:31 PM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
