Go to Post Admitted to MIT '14. FIRST is good stuff. - sparrowkc [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
Pontiac Discount Pharmacy
ADVERTISEMENT
Unread 01-22-2010, 09:41 AM
EricWilliams's Avatar
EricWilliams EricWilliams is offline
FRC #0125 (NUTRONS)
EricWilliams is an unknown quantity at this pointEricWilliams is an unknown quantity at this point
Unhappy 2009 Driver Station Issue
We're trying to fire up the old '09 robot for a demo, and having some trouble. With the DS (2009) tethered directly to the cRIO, we get a strange assortment of "#" signs on the bottom line of the DS screen. The "Status" line changes from "Enabled" to "Teloperated" to "Watchdog" rapidly, spending most of it's time in "Teleoperated". We're getting good communications and a battery voltage readback, but we have no control whatsoever.
Using a laptop, we can ping the cRIO and have reset the team number on the DS to work with the cRIO configuration (10.1.25.2 for cRIO, Team Number 125 for the DS). With a laptop plugged into the DS, we get no response pinging 10.1.25.4, even after setting the team number correctly.
Finally, there is a red light on the PD board at a terminal pair to which there is no load attached or breaker installed. According to the datasheets, the red light only comes on when there is a load connected and the break is not installed. Could this be a related issue?
Does anyone have any suggestions? Due to some personnel change and inherent loss of documentation/code, re-imagining the cRIO or dropping new code on it has to be the final last resort.
As a corallary question, does anyone have a copy of the DS firmware that was handed out during inspection at the regional?
Unread 01-22-2010, 10:06 AM
Mark McLeod's Avatar
Itinerant Programmer
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: 2009 Driver Station Issue
I assume this robot has remained untouched from last season?
No cRIO image updates, etc.?
Do you remember the last time someone downloaded code to it at the end of the season, and was it run afterwards in competition?
Tethered directly, the DS-to-cRIO needs to use a crossover Ethernet cable, not a normal straight cable.
Are the DS Ethernet status lights coming on?
Did you try both ports with your laptop ping test?
Is your PC Ethernet port auto sensing?
I do have the DS firmware here
"Everyone you will ever meet knows something you don't" - Bill Nye
Unread 01-22-2010, 10:22 AM
FRC #0125 (NUTRONS)
The ethernet cable we were using might not have been a cross-over. The cRIO should not have been touched since the last time it was running, which would have been mid-fall 2009. The DS Ethernet ports do light up with both connections, and we have used both ports. We were using the Classmate PC to ping the DS, but I'm under the impression that is not auto-sensing.
I will check the details when we get back to the lab, and also reflash the driver station. Thanks for the link and the help.
Unread 01-22-2010, 10:33 AM
The classmate is actually auto-sensing, so no worries there.
Ping wouldn't have worked otherwise, so my question about that was unnecessary.
The 2010 Control System documentation is misleading in the case of the Classmate auto-sensing.
Unread 01-22-2010, 01:42 PM
no team (Team NI)
The 2009 and 2010 driver stations are largely interchangeable. You may as well hook the 2010 to the cRIO and see if the diagnostics tab gives you any more indication of where the fault is.
Greg McKaskle
Unread 01-22-2010, 01:59 PM
FRC #0125 (NUTRONS)
Greg McKaskle
Thanks for the tip, we will do that ASAP.
2010 Driver Station Netbook Driver Account and Java joshholat FRC Control System 2 01-10-2010 02:04 PM
Driver Station Firmware Update 2009-01-22c1 Mark McLeod FRC Control System 4 02-09-2009 10:52 AM
2009 Driver station schematics Japper FRC Control System 3 01-24-2009 09:30 AM
Driver Station Watch Dog / Motor Won't Spin Issue RMiller FRC Control System 5 01-20-2009 08:58 AM
2009 Driver Station Dimensions noxryan FRC Control System 5 11-27-2008 08:02 PM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
