Go to Post I swear, sometimes it seems like FIRST has got a room full of monkeys writing code. Maybe the monkeys should spend less time flinging fecal matter at each other and more time testing the code before posting it :-). - Kevin Watson [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
Innovation First International, Inc.
ITT Tech
ADVERTISEMENT
Unread 01-22-2010, 07:41 PM
daltore's Avatar
daltore daltore is offline
Electronics/programming/design
AKA: Aaron Osmer
FRC #3529 (ausTIN CANs)
Rookie Year: 2007
daltore has a spectacular aura aboutdaltore has a spectacular aura aboutdaltore has a spectacular aura about
Send a message via AIM to daltore Send a message via MSN to daltore Send a message via Yahoo to daltore Send a message via Skype™ to daltore
TB Nano Encoder Spacing
We got two Toughbox Nano's this year for our mechanum drive, and tonight we started mounting encoders. But there seems to be a problem - the entire drive shaft wiggles axially by about 1mm on one and 1.5mm on the other. Since the encoder disks mount directly to this shaft, we're worried that this may cause the disk to get out of focus, or even possibly crash. Has anybody else noticed this issue, and what's your opinion of the wiggle room on the encoders?
Unread 01-22-2010, 10:50 PM
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Send a message via AIM to Alan Anderson
Re: TB Nano Encoder Spacing
The E4P encoders are remarkably tolerant of slop in the shaft. I'd still look closely to see if there's a place you ought to install a spacer in the gearbox.
(It sounds like you might be trying to do mecanum drive with only two gearboxes. I hope I'm reading that wrong.)
Unread 01-23-2010, 08:54 AM
daltore's Avatar
AKA: Aaron Osmer
Rookie Year: 2007
I'm not sure it's going to be that easy to install a spacer. We definitely could, it should just be a large washer, but we'd have to take the E-clip off, and then the whole gearbox would fall apart. But it's good to know US Digital knows what they're doing. I am still worried about the whole millimeter and a half, though, but I guess we'll just have to give it a go and see how it turns out.
Unread 01-23-2010, 08:38 PM
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Dad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud of
We put an extra washer in the output shaft and removed the endplay. I believe the students put it on the 'encoder' side of the shaft.
We used a screwdriver, modified by bending the tip 90 degrees, to pull out the c-clip and the output shaft pulls right out.
Unread 01-23-2010, 11:39 PM
daltore's Avatar
AKA: Aaron Osmer
Rookie Year: 2007
Thanks, we'll try that if we encounter any problems. They've already got the encoders mounted, so for right now we'll just see how it goes. I'll keep you posted.
Unread 01-24-2010, 10:17 AM
Dale's Avatar
Dale Dale is offline
Head Coach & Mentor
AKA: Dale Yocum
FRC #1540 (Flaming Chickens)
Team Role: Coach
Dale has much to be proud ofDale has much to be proud ofDale has much to be proud ofDale has much to be proud ofDale has much to be proud ofDale has much to be proud ofDale has much to be proud ofDale has much to be proud ofDale has much to be proud of
We also installed a nylon washer on that shaft. It's hard to imagine the encoders would work well with that kind of play in the axle. Even if they did, you'd have to be careful when installing the encoder to do it in such a way that the disk wouldn't run into the housing/sensor when the axle is at one end or another of it's travel.
2013 Chairman's (Oregon); 2013 Finalist (OKC); 2012 Winner (OKC); 2012 Chairman's (OKC); 2012 Woody Flowers (Oregon); 2012 Imagery (Oregon); 2011 Volunteer of the Year (Oregon); 2011 Finalist & Captain (San Diego); 2011 Innovation in Control (San Diego); 2010 & 2007 Chairman's (Oregon); 2010 Regional Champions (Colorado); 2010 Innovation in Control (Colorado); 2009 & 2008 Engineering Inspiration (Oregon); 2008 Regional Champions (Oregon); 2007 Regional Finalist (Oregon); 2005 Rookie Inspiration (PNW)
Trackball Spacing arhajder General Forum 4 01-25-2008 10:01 AM
pic: 2 ringer spacing Ryan Foley Extra Discussion 3 01-07-2007 12:31 AM
Gear Spacing Help AdamHeard Technical Discussion 2 01-06-2007 11:20 PM
Spacing of wheels? archiver 2001 4 06-23-2002 09:56 PM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
