Go to Post The big lesson we learned ... our past does not limit our future, that superior attitude will beat out big budgets. - Dr.Bot [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
Innovation First International, Inc.
Pontiac Discount Pharmacy
ADVERTISEMENT
Unread 01-24-2010, 10:24 PM
remulasce's Avatar
remulasce remulasce is offline
Code Associate
FRC #0597 (Wolverines)
Rookie Year: 2007
remulasce is a splendid one to beholdremulasce is a splendid one to beholdremulasce is a splendid one to beholdremulasce is a splendid one to beholdremulasce is a splendid one to beholdremulasce is a splendid one to beholdremulasce is a splendid one to behold
Driver station can't find io module
The problem is that when I try to connect the io station to our control laptop, it cannot find the io station. We have downloaded the v2 code to the iostation, but the driver station cannot find the io station on either the driver station netbook or a different laptop. The service that is supposed to be running is running, and a green light is lit on the iostation, so we have power. Any ideas on how to fix this?
Unread 01-24-2010, 10:34 PM
Gary.C Gary.C is offline
OUTWORK US
FRC #1323 (MadTown Robotics)
Team Role: Operator
Gary.C has a brilliant futureGary.C has a brilliant futureGary.C has a brilliant futureGary.C has a brilliant futureGary.C has a brilliant futureGary.C has a brilliant futureGary.C has a brilliant futureGary.C has a brilliant futureGary.C has a brilliant futureGary.C has a brilliant futureGary.C has a brilliant future
Send a message via AIM to Gary.C
Re: Driver station can't find io module
Run the DS Update again and when it pops up what to install remove the cypress components and then let it finish. Then run the DS Update again and have it install the cypress components. It should appear in the driver station after that.
Unread 01-25-2010, 12:24 AM
nathanww nathanww is offline
Hacker
FRC #1678 (Citrus Circuits)
Rookie Year: 2007
nathanww is just really nicenathanww is just really nicenathanww is just really nicenathanww is just really nice
Are you plugging into the USB hub? And if so, are other devices on the hub working?
We discovered a few days ago that the RED USb plug on the hub is only for power. If this is the only one connected, nothing will work even though stuff will light up.
Get yer robot source code here!
2010 Driver Station Netbook Driver Account and Java joshholat FRC Control System 2 01-10-2010 02:04 PM
Can't change team # (was: Driver Station problem) Lilszamora FRC Control System 2 02-03-2009 03:26 PM
Can't find frame generator xrabohrok Inventor 2 01-14-2008 03:11 PM
Can't find .h files pmzq Programming 2 01-24-2006 12:03 AM
Can't find CD? Trinora 3D Animation and Competition 2 01-10-2004 01:47 PM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
