Wiring Gyro
My team is choosing to use the gyro that is connected to the accelerometer, and we can't figure out which pins to solder, and where the wires go. Could anyone help?
Re: Wiring Gyro
The sensor manual tells all. Read it.
http://usfirst.org/roboticsprograms/...nt.aspx?id=452 - Click on the Sensor Manual under Section 8 (the robot). If you look in the sensor manual for the gyro board, It will show you a picture. In that picture, look at the left column of terminals with the pins. They are Rate Out, +5, GND in that order, top to bottom in the picture. |
| Gyro wiring? | Phoenix Spud | Electrical | 7 | 01-12-2009 12:58 PM |
| Help: wiring ADXRS300EB Gyro Eval Boards | de_ | Sensors | 3 | 03-18-2008 09:21 PM |
| 2003 Gyro Wiring Harness | DukesAZ | Electrical | 3 | 02-03-2005 05:20 PM |
| 2003 Gyro Wiring Harness | DukesAZ | Technical Discussion | 3 | 02-03-2005 05:20 PM |
| wiring? | SPARKY1688 | Electrical | 4 | 01-31-2005 04:44 PM |
