Go to Post You do realize that you all started jumping to conclusions without asking first which JVN he was talking about. - Jay H 237 [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
Kettering University
ADVERTISEMENT
Unread 02-13-2010, 05:25 PM
greatman05 greatman05 is offline
AKA: Chavez Clemons Jr.
FRC #2224 (Phoenix Phenoms)
greatman05 is an unknown quantity at this point
Send a message via AIM to greatman05 Send a message via MSN to greatman05 Send a message via Yahoo to greatman05 Send a message via Skype™ to greatman05
Question Can't get cRIO to connect to Driver Station Software
Hello. I've been having this continuous problem with setting up the cRIO for communication with the driver station. I've upgraded the firmware for the cRIO (by the way, what is the version or date supposed to say for the updated firmware on the cRIO when you start the cRIO Imaging Tool?), and I've hooked up everything as necessary for the benchtop test; however, it won't connect. There are two red lights next to "Robot Code" and "Communications". How can I fix this? I'm running the software on another laptop (we sent our Classmate in to the company for an RMA).
Unread 02-13-2010, 06:44 PM
Greg McKaskle Greg McKaskle is online now
no team (Team NI)
Re: Can't get cRIO to connect to Driver Station Software
The cRIO needs be v19 or v20, depending on which update you have.
Communications is a summary of the others. If the only thing you are missing is code, I'd open the dev tool, setup the sample project or even an example, and run. Be sure to leave the DS on and running so that you can enable the robot once you have code.
Greg McKaskle
Unread 02-13-2010, 09:33 PM
OK...By the way, here's another question: During the flashing process, is it normal for the robot to disconnect and reconnect a couple of times?
By that second part, do you mean to download the default code and run it, and then try to enable it through the driver station?
Also, when I hooked up the Analog Breakout and the other breakout (default is slot 2), I got a red light under "Robot" in Diagnostics when it usually was green. How do I fix that?
Driver station can't find io module remulasce FRC Control System 2 01-25-2010 12:24 AM
Can't connect your imaging tool to the cRIO? jman1783 Control System 0 01-24-2010 01:07 PM
Wireless Router to Connect with Driver Station Happyisgood FRC Control System 15 09-03-2009 11:02 PM
Can't change team # (was: Driver Station problem) Lilszamora FRC Control System 2 02-03-2009 03:26 PM
cant get NXT to connect to controller station via bluetooth cougarbotics FIRST Tech Challenge 5 12-03-2008 11:19 PM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
