Go to Post I see people show up to a competition with their masterpiece, and proud of it. They are inspired by what they have accomplished. To make it onto the field is a high-it is the culmination of the thousands of hours of dedication compromises and commitment. They feel on top of the world. That's FIRST. - fox46 [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
ITT Tech
ADVERTISEMENT
Unread 02-16-2010, 10:27 AM
gamemonk0 gamemonk0 is offline
John Nguyen
AKA: John Nguyen
FRC #0151 (Tough Techs)
Rookie Year: 2007
gamemonk0 is an unknown quantity at this point
Cannot Connect to Camera through cRIO
When we connect to the camera directly from the laptop via crossover, we can get the feed by accessing its IP address (192.168.0.90) in the browser just fine.
However, when it's connected to port two of the cRIO, we can't connect to it, or get it to feed to the driver station.
We can deploy code just fine, and we have the latest (as in the update released literally yesterday) version of the driver station, gyro compass and all.
Can anyone give us some help or point us towards a guide or something, because I haven't been able to find one of those online either?
Unread 02-17-2010, 05:07 PM
John Nguyen
AKA: John Nguyen
Rookie Year: 2007
Re: Cannot Connect to Camera through cRIO
Problem resolved.
Unread 02-18-2010, 11:54 AM
unobtainium-42's Avatar
unobtainium-42 unobtainium-42 is offline
Team President
AKA: Eric Eaton
FRC #0670 (Homestead Robotics Team)
unobtainium-42 is an unknown quantity at this point
It would be more helpful if you explained how you resolved it.
The network jack on our cRIO did not turn on. The camera needs a crossover cable. Then, apparently you can get it to work by using AxisCamera &camera = AxisCamera::GetInstance(); and setting the parameters (in the constructor).
Unread 02-18-2010, 11:09 PM
John Nguyen
AKA: John Nguyen
Rookie Year: 2007
So sorry.
We solved it by updating everything. It seems that, somehow, one of our freshmen had managed to update the driver station without the necessary LabView update. So once we got our hands on that and re-updated the driver station as well, we began to start getting camera feed. Hope this helps.
Unread 02-20-2010, 10:43 AM
Safety3rd Safety3rd is offline
FRC #3140
Safety3rd is an unknown quantity at this point
Originally Posted by gamemonk0 View Post
So sorry.
now where do you find the updates and everything? what website do you go to or does the driver station have a link to check for updates.
Unread 02-20-2010, 11:44 AM
sp33chy sp33chy is offline
FRC #3332
Rookie Year: 2010
sp33chy is an unknown quantity at this point
Quick question... what parameters?
I do call getInstance() (java) but I didn't know I needed to set any other parameters? I can't get this camera to work so maybe thats what I'm missing?
Unread 02-20-2010, 02:38 PM
FRC #3140
So sorry.
Unread 02-20-2010, 06:37 PM
Team President
AKA: Eric Eaton
I'm not sure how you don't know where the updates are, they are mandatory and on FIRST's website:
http://www.usfirst.org/roboticsprogr....aspx?id=10934
Make sure the cRIO's port that connects to the camera turns on its LEDs so the camera has the potential to communicate. I believe this requires a crossover cable.
Include the following lines in the class inheriting SimpleRobot's constructor:
Code:
// we just got these lines from the example 2010ImageDemo
camera.WriteResolution(AxisCameraParams::kResolution_320x240)
camera.WriteBrightness(0)
After doing just that, our camera works great, even if it's disconnected or booting it will still eventually start the image feed when the camera goes online.
Cannot connect to cRIO from WindRiver Darkknight512 WindRiver C++ 8 01-25-2011 06:42 PM
Cannot connect Windriver to robot abpahl WindRiver C++ 4 02-19-2010 07:28 AM
Cannot connect to cRIO aybose Java 3 02-02-2010 09:20 PM
I/O Board Cannot Connect Haragorn FRC Control System 2 01-14-2010 12:50 PM
Cannot Connect to Axis Camera Wirelessly computerish Technical Discussion 4 01-11-2009 06:19 PM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
