How are they going to inspect for a 3" incursion
Anyone know how they are going to determine that the soccer ball goes into your robot 3 inches? The ball is made up of sown together sections so it can vary in depth.
One of our engineers found that a regualtion bowling ball is the same size as the soccer ball. Hmmmmmmmm |
Re: How are they going to inspect for a 3" incursion
-dave . |
This is just my opinion, but it would be easiest to have a standard regulation ball at inspection so the inspectors can check that, on a flat ground just sitting there, a ball can't go more than 3 inches in. Yes, the ball won't be perfectly round, but it should be close enough... If the inspector sees any trouble spots, he can first warn the team, and second warn the refs. Then the refs just need to watch those trouble spots and for any obvious problems (like teams coming over a bump and landing on top of a ball).
It's going to be impossible for a ref to determine on the fly if your robot allows a 3 inch incursion under normal conditions - that determination almost has to be done off the field. |
Usually they use a jig. I would guess a simple square tube with a 3 inch piece screwed to it. Then they'll slide the bar back and forth to check the areas.
aw crap. here we go again....
And I agree that the best way to do this is to have the inspectors notify the referees of the possibility of the ball rolling 3" or more under your robot. Last edited by Daniel_LaFleur : 02-17-2010 at 12:40 PM. Reason: Unintended posting |
Don't worry, the game piece will never be a bowling ball. They are too hard to wear.
You are going to be wearing soccerballs?
I'm not but I'm sure someone will think of something. I'm sticking with my cool Converse and tie-dye.
#10
How "un-round" are soccerballs? Are we arguing over thousandths of an inch? Hundreths? Tenths?
#11
I think 148 is going to make a point of demonstrating to head-refs that balls cannot enter our robot more than 3". Education may be the key to avoiding penalties from over-eager flag throwers. I can only imagine the reaction from our new coach if we get such a penalty... ![]() -John |
#12
Daniel and John, <R19> clearly specifies that the robots must be designed so that the balls cannot go more than 3" inside the frame perimeter during normal operation.
This then becomes an inspection issue, because the inspectors need to check the normal operation parameters for the 3" incursion, whether or not it happens on the field. I'm thinking that a rig like the inspectors had last year for the bumper/trailer hitch checking would probably do the trick. One side bumper, one side ball. If it catches something, grab a ball from the practice field or the field stash to verify. |
#13
Well, sort-of. (already posted in cdmedia)And I've upgraded to glitter Converse this year. |
#14
I'm curious about what the refs are going to do if a ball fence on a robot gets bent or tweaked during competition and lets the ball in, say, 4 inches. They would have a hell of a time seeing that from 30 feet away...
#15
| For some reason our motors are "breaking" and not going forward. Why? | Bensky | Programming | 3 | 01-25-2008 12:39 PM |
| Why are they showing us how to build a chasis? | Leav | Technical Discussion | 16 | 01-09-2005 11:29 PM |
| How are they going? | Mullet | Chairman's Award | 2 | 02-01-2003 02:13 PM |
| When are they going to finish the FIRST EDUrobot- a primer for success website? | team222badbrad | Robotics Education and Curriculum | 0 | 12-28-2002 06:10 PM |
