Robot code won't load
We are unable to load code to the cRIO at all. In WindRiver, all the settings are properly set, but Deploying code stopped working after a while. For a while, we manually put the .out file into the /system/startup directory on the cRIO, and that worked for a while, but then that stopped working too. Instead of loading the new code, it used an older version of the code we were using. We tried re-imaging the cRIO (image v20), and while it deleted the old code, it didn't fix the issue with being unable to load in any new code. Does anyone have an idea what's going on?
Re: Robot code won't load
It wouldn't hurt to check the flash file system... -> chkdsk "/c" Reliance File System Integrity Checker Datalight Reliance v3.2.2 Buid 1376BV VxWorks Editio for ppc603 Copyright (c) 2003-2008 Datalight, Inc. All Rights Reserved Worldwide. Checking 19M Byte drive Checkingcritical meta blocks...............................1OK Checking indices........................................... .5OK Checking all drectory contents and inode...................79OK Cecking allocation map.....................................OK Checkng for stranded blocks.........................6891OK relFsChk complete. Volume Information: 125,583,360 bytes in volue 22,847,488 bytes i 138 files 163,840 ytes in 20 directories 49,152 bytes system ovrhead 102,522,880 byts available for use 8,192 bytes per block 15,330 total block in volume 12,515 locks available value =0 = 0x0 Edit: the output of the chkdsk command clearly lost some characters. :-( Last edited by gvarndell : 02-17-2010 at 03:58 PM. Reason: note the dropped characters in pasted text |
are you building the code?
are you uploading the just built code? are you sure you are uploading the just build code? try rebuilding (right click project> Rebuild) also |
also, note:
if you're using a new project than the old one, don't forget to point the FIRST downloader to your new project's .out file. |
| How do I load the default code? | HarryScheiner | WindRiver C++ | 7 | 02-11-2009 10:52 AM |
| **FIRST EMAIL**/Important Pit Load In and Load Out Information | Mark McLeod | FIRST E-Mail Blast Archive | 7 | 04-11-2008 07:16 AM |
| Can we load 2004 code? | colt527 | Programming | 5 | 02-15-2005 06:48 PM |
| Album won't load... | Lisa Perez | Website Design/Showcase | 3 | 07-04-2004 11:41 PM |
| How long does it take you to load the default code? | vegasmcse | Robotics Education and Curriculum | 10 | 11-03-2003 08:41 PM |
