Go to Post Aaaaah! I think my head just exploded from looking at this awesomeness. You guys are great. This is super cool. :) - Ian Curtis [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
Kettering University
ADVERTISEMENT
Unread 02-20-2010, 01:26 PM
CottonBall CottonBall is offline
FRC #3049 (Fluffy Robotics)
Team Role: Leadership
CottonBall will become famous soon enoughCottonBall will become famous soon enough
cRIO Trouble ((User 1 and Status Issue))
So yesterday upon fixing the errors in our programming and all that we attempted to download and use code today. We powered on our bot and was scratching our heads at the errors we keep getting. we checked our wiring and everything. The cRIO gets the power light and all lights on the electrical are all working and right. However, on the cRIO the User 1 and Status light don't work.
As well as not registering a voltage, despite having the jumper in the right spot.
We doubled checked our wiring, tried hooking up directly to the cRIO and have spent the last three hours trouble shooting the issue.
We are in dire need of help, we are closing in on shipping day and if the cRO doesn't work right we won't be able to compete this year. If we can't fix the issues we'll hold back the cRIO to do so.
Unread 02-20-2010, 10:58 PM
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Send a message via AIM to Alan Anderson
Re: cRIO Trouble ((User 1 and Status Issue))
Can you show us one of these head-scratch-prompting errors? Someone here might understand it better than you do right now.
What do you expect the User 1 and Status lights to be doing? What are they doing instead?
You say the power jumper is in the right spot, but is that spot itself in the right spot? Is the jumper on an Analog Breakout board atop the AI module in slot 1, and does it have 12V power connected - in the correct polarity -- to it? Is its green power light lit?
Unread 02-20-2010, 11:15 PM
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Itinerant Programmer
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
The cRIO Status LED usually lights only when the cRIO is reset.
The cRIO User 1 LED only lights if you set it yourself in your code.
They aren't going on when these things happen, and all Driver Station statuses are green?
"Everyone you will ever meet knows something you don't" - Bill Nye
Unread 02-21-2010, 11:37 AM
Ok well after fiddling with it all day we actually figured out what was wrong....which was many thing. After going backwards a bit with progress we managed to fix it all yesterday before the end of the day. then we burnt yet another motor controller. Anyways. the issue has been resolved and I really do need to try to describe the issues better but it's kinda hard to do when you don't even know what's wrong in the first place, other then the fact it's not working how we want it.
Trouble flashing cRIO sp33chy Programming 20 02-22-2010 11:05 AM
Status driver station issue batmankiller Control System 3 02-19-2010 10:31 AM
Trouble connecting to cRIO? darty Programming 17 01-31-2009 03:15 PM
cRIO Application Loader Issue 7-11number1 WindRiver C++ 3 01-28-2009 09:20 PM
Trouble using Kevin Watson's Serial Code with Vex user API StargateFan Programming 3 01-13-2007 02:42 PM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
