Go to Post FIRST describes this program as students working "side by side" with professional mentors. We describe our team as working "shoulder to shoulder." Maximum learning happens with maximum interaction between students and mentors, whenever and wherever that may be. - jspatz1 [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
Delphi
ADVERTISEMENT
Unread 04-05-2010, 05:09 PM
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Gray Jaguar CAN closed-loop speed control
Was any team successful in running closed-loop speed control this season with Gray Jaguars with the optical encoder signals going directly to the Jaguars ?
If so, I have a LabVIEW programmer here who would like to work on this off-season because he never got a chance to do it this year, and he has some questions.
My understanding is the following:
- he will have to update the firmware on the jags
- he will have to use some sort of 3rd-party RS232-to-CAN converter bridge (because the Gray Jags do not have this functionality)
- there is no built-in support for the Jaguar CAN interface in the 2010 FRC LabVIEW installation, so he will have to use 3rd-party VIs from WPI located at http://firstforge.wpi.edu/sf/projects/canjaguar
- the 3rd-party WPI VIs do not support all the control and monitoring capabilities that the Jaguar offers (or so I am told)
Is the above correct? Are there any other issues to be aware of?
Finally, is there a technical document for the Gray Jaguars that explains the Jag's API in sufficient detail that he could develop his own VI if he wanted?
Thank you.
Unread 04-05-2010, 06:58 PM
timmmoore timmmoore is offline
FRC #1899
timmmoore is on a distinguished road
Re: Gray Jaguar CAN closed-loop speed control
We used 1 black jag for rs232/can and encoder, 3 greys with encoder and 1 grey using limit switches. The 1 black and 3 greys were for a mecanum drive, the 4th was for our arm.
1. Update firmware to 90 or 91 on both black/grey
2. we used 1 black jag as the interface
3. We used version 39 from WPI + mods
4. version 39 has a lot more monitoring, see the speed control tuning vi and dashboard. We used current, limit switches and speed monitoring back to our dashboard for testing/debug
5. If you want to use mecanum you will need to mod the CAN mecanum for speed control - not that difficult or I can find our changes.
For some reason in speed mode the motor invert on the open isn't passed through, we modified the vi to handle the invert booleans
Unread 04-06-2010, 11:59 AM
Ether's Avatar
Rookie Year: 1969
Are you aware of any teams which did not have black jag and used a 3rd party interface successfully?
Does the 3rd-party (WPI) CAN mecanum VI use the Jag's built-in PID speed control, or is that the mod you are talking about ?
Was your team's primary motivation for using CAN to get speed control?
If so, did you do this because open-loop voltage control did not give the driver satisfactory control of the robot in TeleOp?
Did you use the Jag's position control in autonomous for more accurate positioning?
Unread 04-06-2010, 12:19 PM
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Rookie Year: 2010
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
I know of many teams that used the 2CAN as an ethernet-CAN interface, nothing else was FRC-legal
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Unread 04-06-2010, 12:20 PM
EricVanWyk EricVanWyk is offline
Rookie Year: 2000
EricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond repute
Send a message via AIM to EricVanWyk
I only got to go to one regional this year, but I saw a fair number of teams using CrossTheRoad's 2CAN.
Unread 04-06-2010, 02:38 PM
FRC #1899
We were the only team I saw at the Seattle regional using CAN.
That was the mod I was talking about. We had code for both the original mecanum vi and the modified vi and we used the CRio USER1 switch to switch between them. This was because we have had relability issues with encoders in previous years and we wanted a way to try both.
We wanted it for autonomous but we didn't get the time to test with and without speed control. We used both during the regional, a wire broke on one of the encoders and we switched speed control off. The feedback from the drivers was it drove better without speed control though that may have been because they were driving with the wiring problem before we found we had a problem.
The drivers found open-loop was easier to drive, we havent had a chance to find out why.
Never got to test that.
Unread 04-13-2010, 10:10 PM
FRC #1899
Here you go, this is the CAN version 39 from WPI with our extensions. The new files are:
CAN Jaguar Set Output Speed.vi
CAN Jaguar - Open4MotorSpeed.vi
CAN Jaguar - MecanumDrive_PolarSpeed.vi
we also updated CAN Jaguar HolonmicDrive.vi so PolarSpeed is another option within it.
Tim
Help with CAN bus closed-loop speed control RoboGuy Programming 16 04-14-2010 11:34 AM
Closed Loop Speed Control kgzak NI LabVIEW 16 03-29-2010 08:27 PM
closed-loop torque (current) wheel control for mecanum Ether Programming 3 02-06-2010 11:54 PM
PID control loops - closed loop feedback KenWittlief Technical Discussion 56 04-26-2004 08:27 PM
How Can You Make A Closed Loop System???? GRR_340 Pneumatics 6 03-21-2002 11:27 AM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
