Go to Post ...Al Skierk, uh, Skierwike, uh, you know who I mean - Gary Dillard [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
Chief Delphi Alumni
ADVERTISEMENT
Unread 04-19-2010, 12:40 PM
steelerborn's Avatar
steelerborn steelerborn is offline
Creo Mentor, Treasurer Tau Beta Pi
AKA: Jonathan Stokes
FRC #1671 (Buchanan Bird Brains)
Rookie Year: 2007
steelerborn is a splendid one to beholdsteelerborn is a splendid one to beholdsteelerborn is a splendid one to beholdsteelerborn is a splendid one to beholdsteelerborn is a splendid one to beholdsteelerborn is a splendid one to beholdsteelerborn is a splendid one to behold
pic: 1671 Swerve Module
Unread 04-19-2010, 12:42 PM
CraigHickman
Posts: n/a
Re: pic: 1671 Swerve Module
Originally Posted by steelerborn View Post
Slick! Care to answer some questions about your design? More specifically, why cantilever the belts, rather than put them inside the module? Also, I love the use of belts. When routed correctly, they outperform chain in both lifetime and torque transmission.
Also, a tip on top support crab modules: For FRC level contact, you might find yourself wanting more support on that top pivot. Even a single degree of deflection of the module makes you lose 90% of your contact patch on the ground...
Unread 04-19-2010, 02:12 PM
Rookie Year: 2007
Thanks
I was actually thinking about putting the belt sprockets on the inside of the module. But I then thought that having them on the outside will allow easier access to the belts. We have never used belts before does it matter how easy they are to access?
Good enough is the enemy of anything great!
Unread 04-19-2010, 02:16 PM
martin417's Avatar
martin417 martin417 is offline
Opinionated old goat
AKA: Martin Wilson
FRC #4509 (Mechanical Bulls)
martin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond repute
We used belts exclusively this year, and even though we had some slippage during shoving matches and bump crossings, we never had to replace a belt, and no visible wear occurred. So no, I don't think you need access.
Former mentor Team 1771
Mentor Team 4509
Unread 04-19-2010, 02:24 PM
Rookie Year: 2007
Okay, thank you guys.
I will modify the cad today it is a pretty quick fix.
Unread 04-19-2010, 03:10 PM
CraigHickman
Posts: n/a
Thanks
As long as it's properly tensioned, the system should be fine. However, properly tensioning and aligning belts can a bit of a dynamic situation when in FIRST. Constantly flexing frames can lead to sudden losses or gains in tension, unless you can design a quite rigid chassis.
I really dig the direction you're heading in, so keep it up! A Belt drive crab isn't common, and if you can pull it off it ought to yield some nice weight advantages.
Unread 04-19-2010, 04:27 PM
Rookie Year: 2007
Yeah I have wanted to use belts for quite some time now. But we were nervous about starting it without testing so we waited for the offseason to come around.
Yeah a weight advantage is always good to have.
Unread 04-19-2010, 05:39 PM
Jamie Kalb's Avatar
Jamie Kalb Jamie Kalb is offline
how VEXing...
VRC #3129 (Green MacHHHHine)
Jamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to all
Looks nice! Is it based on the 118 swerve modules (or 221's "Revolution Modules")?
If you're going to run a swerve with belts, you should look into 1717's 2010 machine:
They might be able to give you some advice on it.
You said this is for an off-season project? Can't wait to see the final version(s)! Remember to post pictures, and good luck with it.
Edit: One more thing. For an off-season project, this probably won't matter, but for a competition robot, if you have the machining capabilities, time, and budget, you should probably replace those shaft collars with snaprings. Those setscrews have a nasty habit of coming loose at the worst possible times, and snaprings take up a heck of a lot less space and weight, too.
Team 3129 Green MacHHHHine Founder, Captain (2009-10), Alumnus,... and now Mentor !
2009: (FRC Lunacy) - CalGames Highest Rookie Seed Award
2010: (FRC Breakaway) - Silicon Valley Regional Highest Rookie Seed, Rookie All-Star Award
2010-2011: (VEX Round Up) - Cal High Champions; BEL Finalists, Excellence Award; WC Math Division Excellence Award!
2011-2012: (VEX Gateway) - East Bay Driver Skills, Programming Skills, Excellence Award; Tracy Driver Skills, Programming Skills, Champions, Excellence Award; BEL Programming Skills, Champions, Excellence Award; WC RECF Educational Video, Engineering Division Think Award
2011 and 2012 VEX World Championship...
Last edited by Jamie Kalb : 04-19-2010 at 05:43 PM. Reason: Forgot about snaprings
Unread 04-19-2010, 05:56 PM
Rookie Year: 2007
Yeah I looked at the revolution first but wanted to change some things, mainly the use of chain.
1717 does have an awesome swerve I was talking to them about it at the la regional. Our overall base however is using 3 wd in place of the usual 4. So this cuts the weight of a whole module.
I will definitely look into that thanks for the tip.
And yes we will post more pics as time goes on.
Unread 04-19-2010, 06:07 PM
Jamie Kalb's Avatar
how VEXing...
Nice. Keep up the good work.
One more thing I just remembered. I can't tell from the picture, but do you have thrust bearings/bushings in place to distribute the thrust loads from those miter gears? Since the gears are working at an angle, there will be a significant thrust load along their axes. If you don't have a bearing/bushing in place to handle this, you can end up damaging parts very quickly. We found this out the hard way in our worm drive kicker gearbox this year. If you go to the 221 website and take a look at the close-ups of the Revolution (or download the CAD file), I believe you can see the thrust bushings implemented correctly.
Unread 04-19-2010, 06:12 PM
Rookie Year: 2007
Yeah it is hard to tell from the picture, but yes there is bearings in place for that purpose. The angle makes it difficult to tell.
Unread 04-19-2010, 06:15 PM
Chris is me's Avatar
Division By Shaker?
FRC #2791 (Shaker Robotics) (EWCP))
Team Role: Tactician
Any thoughts on replacing the timing belt on the outside with gears, perhaps even with a slight reduction? I imagine that would be a little easier to maintain.
Proud 2791 Mentor (2010-201?) - 2012 BAE Granite State Regional Finalists (with 1519, 885), 2013 WPI Regional #1 Seed / Finalists (with 20, 3182), Beantown Blitz Finalists (with 2168, 4564)
Proud 1714 Alumnus (2009) - 2009 Minnesota 10,000 Lakes Regional Champions (with 2826, 2470)
My Robotics Blog (Updated Mar 15, 2012... I know, I'll get to it.)
Unread 04-19-2010, 06:23 PM
Rookie Year: 2007
Yeah I had looked into that too. I went and looked at 148's swerve system from 2008 (tumbleweed) they used gears on the outside too. But in the end I realized that it really wasn't the direction I wanted to head (light weight module). So I talked with my mentors and they brought up timing belts and showed me a great site for belt parts. But the module frame remained the same.
Unread 04-20-2010, 01:21 AM
Rookie Year: 2007
Okay
I finished the changes on the module tonight and uploaded the new picture. It should be up soon. Thank you guys for all your help.
  #15   Spotlight this post!
Unread 04-20-2010, 07:49 AM
JesseK's Avatar
JesseK JesseK is offline
Flybotix Fanatic
FRC #1885 (iLITE)
During 118's Crab Module Lecture in 2009, they suggested making the reduction after the miter gears as large as possible in order to reduce the amount of torque transferred through the miter gears. This prevented them from slipping under heavy load due to the slightest misalignment. It may also make the gearbox lighter since you might only need a single reduction coming out of it.
Healthy people — who know how to deal with disappointment, who have given up on the idea of magic bullets, who don’t watch TV indiscriminately [are] fulfilled by things that don’t cost money
I’m talking about the real fundamentals of being an empowered, self-directed human being. Creativity. Curiosity. Resilience to distraction. Patience with others. And to make these all possible: self-reliance — an unswerving willingness to take responsibility for your life...
How to Make Trillions of Dollars
Want to be a better cook? Do 5 recipes from Plenty on 5 weeknights after work. Eat the leftovers for lunch.
pic: Swerve Module Concept (View 1) Dave McLaughlin Extra Discussion 15 06-16-2009 09:36 PM
pic: FRC 1771 Swerve Module sdcantrell56 Extra Discussion 17 04-12-2008 11:36 PM
pic: stangs swerve module Aren_Hill Extra Discussion 8 04-23-2007 07:15 AM
pic: Swerve! (Module) =Martin=Taylor= Extra Discussion 13 07-09-2006 06:57 PM
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
