RobotPy: Python for FRC
After being inspired by Ross Light and Team 973's success in porting Lua to the cRIO (see the "Announcing FIRSTLua" thread), I have completed a port of Python to the cRIO, called RobotPy.
RobotPy is a fully functioning port of Python 3.1.2 that can be used for programming your FRC robot. The full set of WPILib functions, including CANJaguar, is available in Python via "import wpilib". As with the Lua port,
I've performed some initial testing on Team 294's 2010 robot, including running CAN bus Jaguars and compressors and pneumatics. Examples and installation documentation are available on the website and are also included in the download. Also, the download .zip file includes a prebuilt FRC_UserProgram.out, so you don't need to have any programming software installed to get up and running (just FTP a bunch of files to your robot)! Please report any bugs you find via the RobotPy website's ticket system (note: registration is required). RobotPy website: http://www.tortall.net/projects/robotpy/ While the download .zip doesn't include the source code, it is available via a git repository. See the Download page on the website for details. With the exception of modules with large dependencies (e.g. databases), almost all of the Python standard library is included. So yes, you can parse XML files with expat on the robot if you so choose . Much of this is untested however (I have not tried to run the Python test suite on the robot).Major thanks go to Ross Light and Team 973; this project would not have happened without them creating FIRSTLua first to inspire me to port Python. RobotPy uses the WPILib SWIG wrapper created by Ross, with the addition of CANJaguar. The idea of using a boot script to auto-reload the user code is also taken from FIRSTLua. |
Re: RobotPy: Python for FRC
thank you so much
![]() I'm already porting my team's high level motor grouper and pneumatics classes, I'm hoping these can be included with your permission, of course |
Of course! I'd love to build up and include (maybe as a separate download) a library of team-built robot-oriented Python modules. And if anyone has suggestions on any other common/useful modules to include, I'll look at adding them as well (NumPy and SciPy come to mind, for example).
I have most of the common inputs that my team used coded in python for prototyping, so I will be done with the whole thing by tomorrow
Do sockets work? That would make it easy to add a telnet server to the robot, and allow remote execution of code to aid testing. Also, does print work correctly? Thanks again for doing this! I'm really excited. |
Yes, print works correctly. Feel free to tackle NumPy and SciPy. FYI, to date, I've been integrating C/C++ modules directly into Python/Lib and Python/Modules/ (and updating Modules/config.c to add them to _PyImport_Inittab), because it's all a static executable anyway. |
where does print go?
The cRIO console. There's a couple different ways to see it; NetConsole is probably the best (see http://www.chiefdelphi.com/forums/sh...ad.php?t=80146).
#10
I have basic driving functions and inputs programmed:
output.py Code:
#Made by Sam Dodrill for Team 2412, WTFPL
from wpilib import Victor, Solenoid
import wpilib
import math
class Driver:
def __init__(self, FL, FR, RL = None, RR = None):
self.FLvictor = Victor(FL)
self.FRvictor = Victor(FR)
if RL != None and RR != None:become standard for the interpreter :)
self.RLvictor = Victor(RL)
self.RRvictor = Victor(RR)
self.fourWheel = True
def drive(self, speed):
self.FLvictor.Set(speed)
self.FRvictor.Set(-speed)
if fourWheel:
self.RLvictor.Set(speed)
self.RRvictor.Set(-speed)
def tankDrive(self, left, right):
self.FLvictor.Set(left)
self.FRvictor.Set(-right)
if fourWheel:
self.RLvictor.Set(left)
def limit(self, n):
if n > 1:
return 1
elif n < -1:
return -1
else:
return n
def arcadeDrive(self, speed, direction):
left = speed - direction
right = speed + direction
maxi = max(left, right)
if maxi > 1:
left = left/maxi
right = right/maxi
left = limit(left)
right = limit(right)
self.tankDrive(left, right)
def holonomicDrive(self, power, slide, spin):
fl = power + slide + spin
fr = power - slide - spin
rl = power - slide + spin
rr = power + slide - spin
fl = limit(fl);
fr = limit(fr);
rl = limit(rl);
rr = limit(rr);
self.setSpeed(fl, fr, rl, rr)
def setSpeed(self, fl, fr, rl, rr):
self.FLvictor.Set(fl)
self.FRvictor.Set(-fr)
self.RLvictor.Set(rl)
self.RRvictor.Set(-rr)
def goLeft(self):
self.holonomicDrive(0, 0.5, 0)
def goRight(self):
self.holonomicDrive(0, -0.5, 0)
def goForward(self):
self.holonomicDrive(0.5, 0, 0)
def goBackward(self):
self.holonomicDrive(-0.5, 0, 0)
def turnLeft(self):
self.holonomicDrive(0, 0, -0.5)
def turnRight(self):
self.holonomicDrive(0, 0, 0.5)
def stop(self):
print("OH CRAP")
self.drive(0)
Code:
#made by Sam Dodrill for team 2412, but you can use it too
import wpilib, math
class Attack3:
def __init__(self, port)
self.joy = wpilib.Joystick(port)
def getX(self):
return self.joy.GetRawAxis(2)
def getY(self):
return self.joy.GetRawAxis(1)
def getThrottle(self):
return self.joy.GetRawAxis(3)
def getTrigger(self):
return self.joy.GetRawButton(1)
def get2(self):
return self.joy.GetRawButton(2)
def get3(self):
return self.joy.GetRawButton(3)
def get4(self):
return self.joy.GetRawButton(4)
#yada yada yada, TODO: finish with all 11 buttons
def calcBuffer(self, n):
buffers = 0.2
if math.abs(n) < buffers:
n = 0
return n
class Xbox:
def __init__(self, port):
def getStick(self, n1, n2): #returns a list in the form of [x,y]
r = list()
r.append(calcBuffer(self.joy.GetRawAxis(n1)))
r.append(calcBuffer(self.joy.GetRawAxis(n2)))
return r
def getLeftStick(self):
return self.getStick(1,2)
def getRightStick(self):
return self.getStick(4,5)
def getButtons(self, n1, n2, n3, n4): #returns a list in the form of [b1, b2, b3, b4]
r = list()
r.append(self.joy.GetRawButton(n1))
r.append(self.joy.GetRawButton(n2))
r.append(self.joy.GetRawButton(n3))
r.append(self.joy.GetRawButton(n4))
return r
def getMainButtons(self): #returns [a,b,x,y]
return self.getButtons(1, 2, 3, 4)
#11
Code Zipped up and is attatched.
First Release, nothing fancy |
#12
Hmm. That does complicate things. Something else to add to the list of prereqs for SciPy. It looks like some of what I assumed was in SciPy is also in NumPy (matricies, for example) so NumPy might be enough. At the very least, it'll help quite a bit.
#14
This is totally awesome. When I saw the Lua thing, I was thinking the same thing, so I'm glad someone took the time to do it. I'll have to try it on the bot later.
#15
I'm super excited to see this! I love Python as a langue, and I can't wait to maybe load this on a practice robot.
| Im doing something wrong here (python) | Robototes2412 | Programming | 9 | 08-30-2010 11:05 PM |
| Programing with Python | Lord Byron | Programming | 5 | 08-25-2009 09:26 PM |
| Looking for FRC teams for calendar fundraiser | SciDKelly134 | Fundraising | 9 | 06-18-2009 10:55 AM |
| Favorite Monty Python Sketch/Movie | Joe Matt | Chit-Chat | 47 | 03-30-2004 08:45 PM |
| monty python [split from thread: big jump, up to 131] | Carolyn Duncan | Chit-Chat | 23 | 07-30-2001 07:46 PM |
