Go to Post Gracious Professionalism does not take a holiday. - JaneYoung [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
Delphi
ADVERTISEMENT
Unread 01-09-2011, 03:39 PM
xxmhw001xx xxmhw001xx is offline
FRC #1241
xxmhw001xx is an unknown quantity at this point
Exclamation Faulty Flash USB?
Hi,
I'm new to the forums and excuse me if i post this in the wrong section, today i tried Flashing my 2010 ClassMate to the new 2011 firmware and it wont seem to work, sometimes it crashes right after loading the files (blue screen) or sometimes it starts and while it is in the script it seems to get an error and stop, then i need to start over again and the problems seem to stay. If someone could please help me it will be highly appreciated.
Thank you,
-Mohammad
Unread 01-09-2011, 07:25 PM
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
Team Role: Electrical
Rookie Year: 2010
slijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to behold
Re: Faulty Flash USB?
http://www.usfirst.org/uploadedFiles...er_Station.pdf describes how to properly re-image the Classmate. http://www.usfirst.org/uploadedFiles...ate_Update.zip contains the BAT file you should use to activate the Windows 7.
Unread 01-10-2011, 03:26 PM
wolfeman wolfeman is offline
Mentor, Team 2590
FRC #2590 (Nemesis)
wolfeman is an unknown quantity at this point
Doesn't work at all for me
With my 2010 Classmate, attempting to boot the USB
flashdrive just gives me "A disk read error has occurred. Press
Ctrl-Alt-Del to restrart"
The thumbdrive itself seems to be fine (reads just
fine on another PC.) Other bootable USB thumbdrives
that I've created (.e.g to image the classmate before
attempting this update) work fine.
I have set the USB thumbdrive first in the boot order in the BIOS.
I've also tried using both USB ports on the classmate (I don't
think that should make a difference though).
Unread 01-11-2011, 08:21 AM
FRC #1241
I have followed the instructions, for me it says the usb is corrupt?
and if your using the 2010 classmates then your usb should be the pop out one, not the swivel one. that will give you that ctrl+alt+del error, i used one of the teams we mentor and had that problem...
anyway i contacted FIRST US and am still waiting for a reply
Unread 01-11-2011, 02:45 PM
Mentor, Team 2590
FRC #2590 (Nemesis)
posted workaround worked for me
The 2011 Image for 2010 Classmate USB stick is definitely
bogus. It's formatted as NTFS even! (2010 was FAT32).
An existing post that I didn't find until after replying here
fixed it for me:
http://www.chiefdelphi.com/forums/sh...ad.php?t=88530
I took the MBR from 2010 USB stick and put that on my
own 4GB FAT32 formatted stick and then copied the 2011
files to that stick. I used Acronis DiskDirector to copy
the MBR. There are open source/free ways to do this as
was well (although they tend to be more labor intensive/expert
oriented)
Unread 01-11-2011, 04:46 PM
FRC #1241
oh ok, im now at acronis and i cant figure how to copy it =( could you help me?
thanks
Unread 01-12-2011, 11:33 AM
Mentor, Team 2590
FRC #2590 (Nemesis)
It depends on the specific version of DiskDirector that you have.
For V10, you just right click on the disk and there's a Copy MBR
item. Then on the target disk you can rwrite that MBR. For
DiskDirector 11 they seem to have removed this nice
feature and instead you have to "edit" the disk and copy
the right number of bytes representing the MBR. What a crock!!
That's the sort of UI regression that's a firing offense. But I digress :-)
Check the on-line help for the version you have and the procedure
should be documented. I had both V10 and V11 and used V10
to do it since it was dead easy. There are free trial versions
of DiskDirector. I'm not sure if this feature is enabled in the trial
version.
Unread 01-15-2011, 10:05 AM
jsamp99 jsamp99 is offline
FRC #0222
jsamp99 is an unknown quantity at this point
I am having the same "disk read error" problem imaging our 2010 classmate. I have limited experience with imaging or mbr editing, so am hesitant to try this. Are there any other solutions out there?
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
