Re-image error 2010 to 2011 - Disk Error
When trying to re-image the Classmate with the 2010 to 2011, I get an error as soon as I select the "Generic" device to boot from. The error says "Drive Error". The only option is to press Ctrl-Alt-Del to start-up again.
Is it possible the drive is corrupt? |
Re: Re-image error 2010 to 2011 - Disk Error
1. Did the Classmate boot properly using the 2010 software before you started?
2. Are you booting with the 2011 Classmate Restoration key into the USB drive? Here's my boot choices with a correctly flashed 2011 Classmate and NO USB key inserted: HDD: PM-SAMSUNG HS030GB USB:Generic- MultiCard Nextwork:Realtek Boot Agent Here's the boot choices with a correctly flashed 2011 Classmate AND a USB key IS mounted: HDD: PM-SAMSUNG HS030GB USB:SanDisk Cruzer USB:Generic- MultiCard Nextwork:Realtek Boot Agent I'm guessing the USB key has not been inserted or there is a fault in the USB key connections. Is the behaviour the same with the USB key in either slot? Last edited by perlgerl : 01-17-2011 at 05:51 PM. |
The Hard Drive Two Generic Flash Drive Network Drive Selecting one of the Generic flash drives yields the drive error. Booting from the other Generic flash boots normally into Windows / 2010 Driver Station |
I agree it sounds like the files on the USB key are damaged. If you have access to a linux machine, the contents should look like this:
http://www.chiefdelphi.com/media/photos/36098 Contact Kate Pilotte FIRST for a replacement. In the meantime you can try downloading and creating your own USB key using these instructions. |
