Go to Post guarantees don't mean anything when you're dealing with FRC good sir ;) - Zuelu562 [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
Pontiac Discount Pharmacy
ADVERTISEMENT
Unread 01-18-2011, 11:55 PM
amoose136's Avatar
amoose136 amoose136 is offline
FRC #3140 (The Flagship)
Team Role: Leadership
amoose136 is an unknown quantity at this point
Question RCX and NXT communication
Does anyone know how to program an NXT to simulate being an RCX's rotation sensor? I want to be able to use one of these and connect together the sensor ports of the RCX and NXT and program them so that the NXT pretends to be a rotation sensor. Programing know how in any language would be appreciated.
I need to know how to do this because this is the only way I know of to use 4 motors without buying another NXT.
Unread 01-19-2011, 07:09 AM
Unsung FIRST Hero
Broadcast Eng/Lead Robot Inspector
AKA: Big Al
FRC #0111 (WildStang)
Rookie Year: 1996
Re: RCX and NXT communication
amoose,
The part that you show is simply an adapter to allow NXT users to connect RCX sensors to their new NXT brick. It does not allow you to simulate using an RCX and NXT together.
Al
WB9UVJ
www.wildstang.org
________________________
Season Eighteen, what a spectacular year! It's has been a bumpy ride. All is better now, new parts are working fine. Champs were spectacular!
Unread 01-19-2011, 08:44 AM
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
There is a legacy block available for NXT-g that will support the older rotation sensor. The cable you reference can connect the older rotation sensor to the NXT. The legacy block(s) can be found as patches at the Lego support site.
However, you mention wanting to control four motors with the NXT. I'm not sure how that's possible with only another rotation sensor. There are other, non-Lego, methods for gaining extra motor control from a single NXT. Perhaps you can be more specific about what you'd like to accomplish with your proposed configuration?
Senior Solutions FLL team 830 - Furiously Natural [pro tem]
FRC team 2170 - Titanium Tomahawks
Unread 01-19-2011, 08:31 PM
amoose136's Avatar
I don't think I made myself clear as to what I want to do.
First, imagine this:
When one rotation sensor is turned by hand, the RCX makes the other's value match it by turning on the motor in the appropriate direction and speed. Thus the motor's motion is dictated by the sensor readings from the rotation sensor. Now picture this:
In this picture the RCX uses the same programing but now the control rotation sensor has been replaced by a NXT programed to emulate a rotation sensor and give the RCX fictitious values.
I want to know how to program the NXT to do this. If I just knew how to control the raw IO from the sensor port on the NXT I think I have an idea.
Unread 01-20-2011, 06:46 AM
Unsung FIRST Hero
AKA: Big Al
Rookie Year: 1996
amoose,
The rotation sensor used in the RCX version is simply a wheel with light and dark places and a photo diode/LED combination. As I remember it gives 16 output transitions per rotation. The NXT version has better resolution and that is why it can be used for angular detection. Remember that the RCX has only two wires per port. I found this in a quick search that might be something interesting for you.
http://www.extremenxt.com/rotate.htm
Al
WB9UVJ
www.wildstang.org
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
