Go to Post A game where you don't have control of your robot for long periods of time is no fun (unless, of course you are talking about autonomous :p) - Cody Carey [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
Cross the Road Electronics
ADVERTISEMENT
Unread 02-02-2011, 04:53 PM
excel2474's Avatar
excel2474 excel2474 is offline
FRC #2474 (Excel)
excel2474 is on a distinguished road
Mini Bot Battery Pack
I was using my battery pack for the mini bot early today, but now, it's not working at all. When I plug it into the charger, no lights light up indicating whether or not it is charging. do you know what could be wrong? Thanks for the help.
Find some thing you like to do and EXCEL at it with dilligence.
Unread 02-02-2011, 05:00 PM
kylelanman kylelanman is offline
Programming Mentor
AKA: Kyle
FRC #2481 (Roboteers)
Rookie Year: 2007
kylelanman is a glorious beacon of lightkylelanman is a glorious beacon of lightkylelanman is a glorious beacon of lightkylelanman is a glorious beacon of lightkylelanman is a glorious beacon of lightkylelanman is a glorious beacon of light
Re: Mini Bot Battery Pack
Check the inline fuse. There is a little cap that you can remove between the battery and the connector. Inside will be a fuse that is most likely blown.
"May the coms be with you"
Is this a "programming error" or a "programmer error"?
Unread 02-02-2011, 05:02 PM
excel2474's Avatar
FRC #2474 (Excel)
How do I check the fuse? I mean, I see it, but what am I looking for that would be wrong with it. If it is burnt, do I have to get a new one, or can I bypass it? Thanks for the help
Unread 02-02-2011, 05:25 PM
pfreivald's Avatar
pfreivald pfreivald is offline
AKA: Patrick Freivald
FRC #1551 (The Grapes of Wrath)
pfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond repute
New fuses are available at any auto parts store for really cheap. I highly suggest you use them, instead of bypassing them!
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
Bausch & Lomb, PTC Corporation, and Naples High School
Like Zombies? Like high school satire? Check out my novel, Twice Shy!
Unread 02-02-2011, 06:17 PM
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Send a message via AIM to Alan Anderson
If all is well, a fuse has a direct connection from one terminal to the other. An ohmmeter will read approximately zero resistance. If the fuse has blown, it will have no continuity between the terminals, and an ohmmeter will read an open circuit.
Unread 02-02-2011, 06:35 PM
excel2474's Avatar
FRC #2474 (Excel)
It seems to be in there pretty tight. Do you know if I am just supposed to pull on it hard enough till it comes out?
Unread 02-02-2011, 06:40 PM
pfreivald's Avatar
You should just be able to pull on it hard enough so that it comes out, yes.
Team 1551
Unread 02-02-2011, 06:44 PM
Taylor's Avatar
Taylor Taylor is offline
It's part of the challenge.
AKA: @taylor1529
FRC #1529 (CyberCards)
Team Role: Teacher
It's in there pretty tight. Pliers help. Don't be afraid of it - what are you gonna do, break an already blown fuse?
Follow @Robot_Chat on Twitter
Sunday 7-8p EST #BotChat
We'll know we've made it when the Goodyear Blimp shows up to regionals.
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
