Go to Post If people really want to see "better" refereeing, they should see what they can do to help FIRST make better. - petek [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
ITT Tech
ADVERTISEMENT
Unread 02-04-2011, 05:00 PM
Derek012's Avatar
Derek012 Derek012 is offline
The most Ultimate of all the Accent
FRC #2648 (Infinite Loop Robotics)
Derek012 is on a distinguished road
Send a message via Skype™ to Derek012
Cypress Switch Problem
Hey,
I've got two switches connected up to our team's Cypress board and I wanted one switch if it was false to be able to make the robot drive with joystick, but if it was true I wanted it to photo sense.
Code:
while (isOperatorControl()) {
            gyro.setSensitivity(0.125);
            dsLCD.updateLCD();
            if (GyroAngle >= 360 || GyroAngle <= -360) {
                GyroAngle = GyroAngle % 360;
            updateDashboard();
            PVal = (int) ((petOm.getVoltage()) * 10);
            dsLCD.println(DriverStationLCD.Line.kMain6, 1, "Arm Angle " + PVal);
            dsLCD.println(DriverStationLCD.Line.kUser2, 1, "Light " + light.getAverageValue());
            dsLCD.println(DriverStationLCD.Line.kUser3, 1, "Gyro Angle " + GyroAngle);
            ds = DriverStation.getInstance();
            if (ds.getDigitalIn(1)) {
                photosense(rite, left, middle);
            else
                if (ds.getDigitalIn(3)) {
                    FullSpeed(r1, r2, l1, l2, rightStick);
                if (!ds.getDigitalIn(3)) {
                    HalfSpeed(r1, r2, l1, l2, rightStick);
Unread 02-04-2011, 05:50 PM
mobilegamer999 mobilegamer999 is offline
AKA: Ben Abraham
FRC #3357 (Comets)
mobilegamer999 is a jewel in the roughmobilegamer999 is a jewel in the roughmobilegamer999 is a jewel in the rough
Re: Cypress Switch Problem
If youre using the Cypress module, you have to use the EnhancedDigitalIO class (or something close to that) instead.
[EDIT]
Just checked, and its DriverStationEnhancedIO is the class name.
so in initialization you would call (Assumin dio is your DriverStationEnhancedIO variable name)
dio = DriverStation.getInstance().getEnhancedIO();
then you can call getDigital on dio to read in digitalIO's
Unread 02-05-2011, 10:21 AM
Derek012's Avatar
I had a problem with the execution of my robot code when I deployed the code and tried to run the robot it wouldn't run the code in operator control
Code:
            display.updateLCD();
            Camera(cam);
            updateDashboard();
            //dsLCD.println(DriverStationLCD.Line.kMain6, 1, "Arm Angle " + PVal);
            //dsLCD.println(DriverStationLCD.Line.kUser2, 1, "Light " + light.getAverageValue());
            //dsLCD.println(DriverStationLCD.Line.kUser3, 1, "Gyro Angle " + GyroAngle);
            try {
                if (dio.getDigital(1)) {
                } if (!dio.getDigital(1)) {
                    if (dio.getDigital(3)) {
                    if (!dio.getDigital(3)) {
            } catch (EnhancedIOException ex) {
                ex.printStackTrace();
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
