Compressor running in disabled mode
We updated to the v27 cRIO image (using java dev) tonight and our compressor now runs in disabled mode. It still cuts off with the pressure switch. Has anything been changed that would cause this to happen? I know the compressor handler runs in a separate thread, but it doesn't seem right that it would override the disabled mode.
If not I suspect something funky is going on with the DSC. |
Re: Compressor running in disabled mode
I've heard of this problem before. The apparent problem was an internal short in the sidecar that cancels the signal to disable relay outputs. jhersh said in that thread though that the next cRIO image would fix the problem. Perhaps the fix got lost?
Running v28 and no problem here |
Team 3518 saw this occur once. It happened after a power cycle of the hostbot which, I believe, may have been too short to allow all internal components to reset.
I have instructed the students on my team to "count to ten" when cycling power on the hostbot. We have not seen the issue recur since adopting this procedure. Regards, Mike BTW, the pressure limit switch did not stop the pump from over pressurizing the system when this was observed. |
Just a quick update. Our bot is still running v27. The compressor runs in disabled mode no matter how long it is off for.
Also, our robot drove in disabled mode at the suffield scrimmage. |
That's a hardware problem. First suspects are the Digital Sidecar or the 37-pin cable connecting it to the cRIO Digital I/O module in slot 4. Less likely would be the module itself, or the DB-15 connector it plugs into on the cRIO.
. We're thinking of just taking out the programming for the limit switch altogether as it's not really needed. So it wasn't electrical, and it wasn't programming. |
#10
Debris is almost always from careless drilling or filing. In both of the cases I saw where it was an accidental connection to battery, the root cause was someone working on the robot structure and letting wires flop around at random. So you're right, it wasn't electrical, and it wasn't programming. It was mechanical. Do we have a new scapegoat? ![]() |
#11
the problem is that for some reason the orange light that needs to go on the robot, when it is not lighting up when the robot is disabled or enabled, the compressor does not work
#13
Oh man, I wish ours would run in disabled mode. If it did, we wouldn't have to try to find the one tiny leak in our complex tubing system.
#14
reported
