Go to Post Mentors can either hide the experience of failure or support the right of a student in gaining that experience. - dcbrown [more]
Go Back   Chief Delphi > Technical > National Instruments LabVIEW and Data Acquisition
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
Innovation First International, Inc.
New Springfield Missionary Baptist Church
ADVERTISEMENT
Unread 03-16-2011, 02:27 PM
Tub Tubs Tub Tubs is offline
FRC #3049
Tub Tubs is an unknown quantity at this point
Extender trouble
Hello, i have made code to program a button to and extender, can any of you help me
Unread 03-16-2011, 02:57 PM
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Send a message via AIM to Alan Anderson
Re: Extender trouble
The SubVI inside the while loop will be called repeatedly with whatever values the buttons had when the loop began. The loop will never end, so it will never provide a value to the Arcade Drive function. Whatever vi this code is in will hang. If it's in Teleop, your robot will be disabled almost immediately by the communication watchdog.
Tell us what you intend it to do and we can probably tell you a good way to make it happen.
Unread 03-16-2011, 11:42 PM
FRC #3049
Extender trouble
I wanted a motor to push a metal bar out of the robot to block other robots
Unread 03-17-2011, 11:14 PM
Danny Diaz's Avatar
Danny Diaz Danny Diaz is offline
AKA: FrankenMentor
FRC #0418 (LASA Robotics / Purple Haze)
Danny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond repute
Send a message via AIM to Danny Diaz
Then why not do yourself a favor and let the hardware do most (if not all) the work for you. In your code (the software side), all you need is to watch the value of a trigger on your joystick (or another button of your choice); once pressed, just tell your motor to "go" - don't worry about telling it to stop, let the hardware handle that for you. On the hardware side, use limit switches plugged into the Jags as stops on your bar; if done correctly, the limit switches will be normally-closed while the Bar is on your robot, and they will be open once your bar extends as far out as it needs to be. The open limit switch will cause the Jag to brake (not "break") the motor, acting as your stop.
There ya go, an incredibly simple mechanism to code and set up.
-Danny
Danny Diaz
Lead Technical Mentor, FRC 418
Unread 03-18-2011, 09:24 PM
Software Architect
What kind of control do you need on the bar? Does it have to move at different speeds at different times, or can it always move at the same configured speed? Does it have to stop in the middle of its travel, or can it always move fully to one end of the other before stopping? Do you want it to extend when a joystick button is pressed and return when the button is released, or do you want it to extend based on one button and return based on a different button? How far do you want the bar to move?
The answers to these questions might point to a solution you aren't thinking of: use a pneumatic cylinder instead of a motor.
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
