pic: Seattle Cascade tubes.
Re: pic: Seattle Cascade tubes.
Those seem to be about twice as big as the ones in Bayou. Glad to see FIRST is improving on consistency across regionals....
That top triangle looks like it could explode at any second.
Wow, I wish FIRST would have some visual control in this!
Speaking of Seattle, any ideas if there is a webcast? I really want to see/cheer on team 3126 from Hollis, NH! |
there is a webcast it's at firstwa.org
firstwa.org should have the webcast.
FIRST does have some control, specifically the templates they send with every field. If the tubes are inflated to the template, they will at the very least be consistent.
At WPI, we inflated them until the tube touched both sides of the template, then stopped. |
Thanks guys!
#10
Yup this is pretty ridiculous, not really a big deal depending on design choices tho
#11
Was the tube size template ever specified in the rules? Gosh, when we were designing our mechanism, the corners of the triangle did not look gigantic like that, and the tube still seemed adequately inflated. Why the need to really fill it so much?
#12
My friend from BC, an alumnus of Trobotics (is Jason here?
) was talking about how the Cascade Regional webcast is far louder than the Olympic Regional webcast. In the pits, Cascade music definitely drowns out Olympic music.About the tubes-- For our practices matches, we've had to make judgment calls during the queue for Olympic because of the discrepancies in tube sizes. We have a strand of latex tubing across our gripper to more easily account for different sized tubes, and we change the tension based on how inflated the tubes are from the queuing line. |
#13
I have it on good authority (from just asking refs and FTAs) that the field manual is pretty sparse on details as to HOW to use the gauge (blow up UNTIL the tube fits vs. blow up and FORCE the tube to fit vs. blow it up all the way and hey, it still fits!). With a compliant object like an inflated inner tube, I have no doubt that a triangle on the verge of bursting could still fit into a 7" gauge... |
#15
What bothers me most about over inflated tubes is that they don't fit through the feeder slot in some cases. If the tube doesn't fit through the slot then don't you think someone would realize that it's too big....? (Also, you know there is a problem when someone who has never been exposed to Logomotion (My Boss/Our Sponsor) can tell that the tube sizes vary a lot more than they should.) |
