Go to Post ...UFH nominations are like jello, there is always room for one more. - Barry Bonzack [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
Team 221 LLC
ADVERTISEMENT
Unread 05-11-2011, 12:59 PM
JamesCH95's Avatar
JamesCH95 JamesCH95 is offline
exFIRST, exFSAE, now FIRST again!
AKA: JCH
FRC #0095 (LRT-UVR Grasshoppers #95)
JamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond repute
Team 95 Thermographics
After many hours of driving the robot (particularly the arm) for a demo-day, we decided to take advantage of CRREL's thermal cameras and take some pictures. We learned some interesting, if obvious, things about the robot.
To reference what our robot looks like: http://r95.org/?p=90
In this picture note the hot window motors that run the arm's gripper, and the warmed area around the roller sprockets on the gripper.
The compressor is very hot, and surprisingly the cRIO is quite warm. The power distribution board and 10awg wire is very cool though.
Under the robot note the slightly warm AM gen-1 shifter transmissions and the VERY warm arm motors. The RS775-18 in the DeWalt housing is a bit hotter than the RS775-18 in the banebots 64:1 P60, presumably the P60 acts as a better heat sink.
Theory is a nice place, I'd like to go there one day, I hear everything works there.
Maturity is knowing you were an idiot, common sense is trying to not be an idiot, wisdom is knowing that you will still be an idiot.
Unread 05-11-2011, 01:44 PM
roystur44's Avatar
roystur44 roystur44 is offline
Mentor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
roystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond repute
Send a message via Yahoo to roystur44
Re: Team 95 Thermographics
James,
The KOP fans are a great thing to add to the robot to cool things down to extend run times. We mount the large fans over the drive motors and we add small fans to the fisher price or bane motors. Another thing we do is add thermistors to the motors and monitor temperature at the drivers station.
Roy
Roy Dumlao
Mentor
2006-2012 971
2013 4543
Unread 05-11-2011, 03:54 PM
sanddrag sanddrag is offline
back to school ;-)
FRC #0696 (Circuit Breakers)
Team Role: Teacher
My experience with the CIMs in both robots and controlled test conditions has indicated that blowing air over them, even at significant volume, has little effect. Under approximately 25 Amps steady continuous load, I could not run a CIM for more than about 4 minutes without it becoming so hot you couldn't hold a finger on it for more than a second or two. This was with a large custom-machined finned aluminum heat sink affixed with thermal compound, and a fan blowing over it. The problem is the heat is all generated in the armature windings, and its only conductive path out is through the bushings in the endbell and the face of the motor. It's a pretty slow heat transfer. It would appear that due to the lack of an internal fan, the convection internally is not really enough to make the CIM motor suitable for extended use.
Support Team 696 on DonorsChoose!
Unread 05-11-2011, 05:02 PM
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
Team Role: Electrical
Rookie Year: 2010
slijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to beholdslijin is a splendid one to behold
The low thermal signature of the main PD circuit is likely because all the plastic casing acts as a good insulator, disguising its true thermal signature. The cRIO part does somewhat surprise me, though.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 05-11-2011, 07:11 PM
Andy A. Andy A. is offline
Getting old
FRC #0095
Team Role: Coach
Andy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond repute
I suspect the cRIO's heat has a lot to do with the runtime we saw that day. The robot had been on for most of the day, even when it wasn't being driven, and of course it's only a few inches from a very hot compressor. The (steel?) housing holds heat pretty well.
Seeing the heat built up around the sprockets in the arm was most interesting to me. We always knew it was a fairly high friction area, but seeing the heat spreading out into the plastic really illustrates the matter. Had I seen that during the build season I might have opted for some sort of further lubrication.
Obviously, thanks goes out to CRREL for taking the time to photograph the 'bot for us. We hope to get some time with the same camera technology during the next build season to help spot friction, bad connections, educational video of machining operations and who knows what else? They've also been a major sponsor of our team since 1996. We've been very lucky to have access to CRREL and the people who work there.
Unread 05-11-2011, 07:16 PM
legogeek24's Avatar
legogeek24 legogeek24 is offline
AKA: Dirk
FRC #3456 (LiveWire)
legogeek24 has a spectacular aura aboutlegogeek24 has a spectacular aura aboutlegogeek24 has a spectacular aura about
Those are some really interesting pictures, that's really cool to have the opportunity to use that camera! I was surprised at the heat of the compressor and cRIO, but I guess running it all day will definitely warm things up!
Unread 05-11-2011, 07:45 PM
goldenglove002 goldenglove002 is offline
AKA: Alex Epstein
FRC #1311 (Kell Robotics)
goldenglove002 is a jewel in the roughgoldenglove002 is a jewel in the roughgoldenglove002 is a jewel in the rough
I love these images. People didn't believe me when I said our window motor was hot enough to burn my hand at our last public event (speaking of, these robots can make for some awesome demos).
2011 Peachtree Regional Dean's List Recipient
2011 Peachtree Regional Kleiner Perkins Caufield & Byers Entrepreneurship Award
2011 Lemelson/MIT InvenTeams Grant
2010 North Carolina Regional Chairmans Award
2010 Peachtree Regional Kleiner Perkins Caufield & Byers Entrepreneurship Award
2010 SeaWorld Busch Gardens Environmental Excellence Award
2009 Peachtree Regional Chairmans Award
2008 Peachtree Regional Judges Award
Unread 05-11-2011, 11:45 PM
JamesCH95's Avatar
AKA: JCH
Thanks!
Yep, those window motors are designed to work for 5 seconds at a time, then rest for quite a while. We were definitely stressing them quite a bit. Luckily, we have many spares
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
