Go to Post How we respect the rules of the game is a reflection of our character and integrity - win, lose, or draw - JaneYoung [more]
Go Back   Chief Delphi > Technical > CAD
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
Chief Delphi Alumni
ADVERTISEMENT
Unread 09-12-2011, 03:41 PM
Mike Harrison's Avatar
Mike Harrison Mike Harrison is offline
Don't Mess with Leila
AKA: The Foof
FRC #0217 (ThunderChickens)
Team Role: Operator
Mike Harrison has much to be proud ofMike Harrison has much to be proud ofMike Harrison has much to be proud ofMike Harrison has much to be proud ofMike Harrison has much to be proud ofMike Harrison has much to be proud ofMike Harrison has much to be proud ofMike Harrison has much to be proud ofMike Harrison has much to be proud of
FEA on parasolids
Anyone know how to perform FEA on a parasolid? I can convert the parasolid to an assembly but I'm trying to avoid this because the parts aren't made to be properly mated together (chassis weldment), making FEA even more of a chore.
I prefer to use Solidworks or Inventor.
Unread 09-12-2011, 04:26 PM
kramarczyk's Avatar
kramarczyk kramarczyk is offline
is getting his kicks.
AKA: Mark Kramarczyk
FRC #3096 (Highlanders)
kramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond repute
Re: FEA on parasolids
Inventor is going to require you to identify the contact conditions of the solid part meshes prior to solving. If you are using bolted and glued joints with no moving interfaces you can probably get along quickly using the automagic feature. On the ribbon: Stress Analysis tab -> Contacts panel -> Automatic
This will basically glue together everything that is clost to touching. If you need something different you can go into the contacts and explicitly edit them, but that is much more time consuming. Having a constrained model would allow you to import the constraints as mesh contacts.
That's about all the help I can offer without seeing the geometery.
Mark
Brick walls are for other people. - Randy Pausch
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
