Go to Post If this truly bothers you, you should do something CONSTRUCTIVE about it instead of whining about it - Jaine Perotti [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
Caroll Turpin
ADVERTISEMENT
Unread 09-21-2011, 09:00 AM
Lucidity Lucidity is offline
Lucidity is an unknown quantity at this point
Wireless not working (Help)
I'd like to start off by saying I'm new around here and I hope that this is in the correct section.
Now onto my problem, last year our robot worked fine and everything was good, then when we came home from the competition our Wireless connection stopped working with our Robot, so now only Hardwiring works.
Suggestions?
Solutions?
Thanks in advance
Unread 09-21-2011, 09:08 AM
Andrew Lawrence's Avatar
Andrew Lawrence Andrew Lawrence is offline
Learning something new every day
AKA: Andrew Lawrence
FRC #0256 (Robo Rams)
Team Role: Tactician
Rookie Year: 2011
Andrew Lawrence has a reputation beyond reputeAndrew Lawrence has a reputation beyond reputeAndrew Lawrence has a reputation beyond reputeAndrew Lawrence has a reputation beyond reputeAndrew Lawrence has a reputation beyond reputeAndrew Lawrence has a reputation beyond reputeAndrew Lawrence has a reputation beyond reputeAndrew Lawrence has a reputation beyond reputeAndrew Lawrence has a reputation beyond reputeAndrew Lawrence has a reputation beyond reputeAndrew Lawrence has a reputation beyond repute
Send a message via Skype™ to Andrew Lawrence
Re: Wireless not working (Help)
I'm just going to go to page 1 of my computer technician handbook, and say what it says there. That has always solved the problem. Here, let's see.....
1. Is it turned on?
-IT SHOULD BE
2. Are all the wires plugged in on BOTH ends?
-Had that problem yesterday
3. Are you connected to the wireless?
4. Is your wireless working?
-You'll probably need a new one if it's not.
5. Do you connect, but can't control anything?
I have tons more questions if you need any!
NEW website? www.Team256.org
Unread 09-21-2011, 09:25 AM
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Send a message via AIM to Alan Anderson
Originally Posted by Lucidity View Post
...when we came home from the competition our Wireless connection stopped working with our Robot,...
If you want the Driver Station to be able to connect wirelessly to the robot without using a separate router, make sure the mode selection switch on the DAP (white wireless network box on the robot) is in the AP ("Access Point") position.
The DAP was reconfigured for WPA security at the competition. Depending on how that was done, you might also need to log on to it using a web browser (http://10.te.am.1, user "admin", blank password) and set wireless security to None.
Unread 09-21-2011, 10:42 AM
EricH's Avatar
EricH EricH is offline
...has read the 2012 Manual
FRC #0330 (Beach'Bots)
Send a message via Skype™ to EricH
I'd start with this one. Most of the "we got home from competition and now our wireless isn't working" problems can be traced to people forgetting about the encryption key being set at competitions.
Paths a rules question takes:
Official: Post to Q&A-->GDC reviews-->Official answer posted on Q&A.
Unofficial: Post to CD-->CD views and comments, sometimes using The Manual and interpreting it-->Somebody goes the Official route -->Answer gets posted on CD eventually, as a quote from Q&A.
Which one takes longer for an official ruling? Therefore, which one makes more sense to use?
Unread 09-21-2011, 11:02 AM
linuxboy linuxboy is offline
AKA: Oliver Graff
FRC #3780 (Robot Unicorn Attack)
linuxboy is a splendid one to beholdlinuxboy is a splendid one to beholdlinuxboy is a splendid one to beholdlinuxboy is a splendid one to beholdlinuxboy is a splendid one to beholdlinuxboy is a splendid one to beholdlinuxboy is a splendid one to behold
Send a message via Skype™ to linuxboy
When you go to program your radio at competition it changes the settings on the radio. I find the easiest thing to do after using that programming kiosk is to just reset the radio and follow the radio configuration instructions from the beginning provided on the Kit Of Parts page.
Mac Camera Configuration Tool
Boston Regional 2012 - FRC 3780 - Imagery Award - Dean's List!
Control System Advisor - Championship 2012 - Northeast Utilities Connecticut Regional 2012
2012 Java & Hardware Beta Test
FTAA - Where is Wolcott Offseason 2011 - Mayhem In Merrimack Offseason 2011
Scorekeeper - Bash at the Beach 2011 - River Rage 15
WPI Regional 2011 - FRC 3780 - Rookie All Star Winners - Safety Pins
Field Reset - CTR 2011 - Boston 2011
Unread 09-22-2011, 06:54 AM
7h0m54's Avatar
7h0m54 7h0m54 is offline
Not just the programmer anymore...
AKA: Tommy F.
FRC #1985 (Robohawks)
Rookie Year: 2010
7h0m54 is just really nice7h0m54 is just really nice7h0m54 is just really nice7h0m54 is just really nice
The first thing I did when I seen the robot was back at our school after going to Championships, I turned it on and reset the radio.
Here's the .pdf file on the FIRST KoP site that you should use right now:
http://usfirst.org/uploadedFiles/Rob...adio_Rev_A.pdf
You should only need to do the Resetting a radio to default settings, and the Configuring a radio for team use steps.
You also might need to do the Connecting to the DAP-1522 via Wi-Fi so you can connect your computer to the radio to do the other 2 steps.
FRC 1985 :: FTC 289, 290 & 291 :: Team 1985's Wiki Page :: Team 1985's Website
2013 St. Louis Regional Semi-Finalist (with 3411 and 4330), Industrial Design Award
2013 Queen City Regional Winner (with 379 and 447)
Unread 09-23-2011, 12:21 AM
daniel_dsouza daniel_dsouza is offline
does what needs to be done.
FRC #2134 (AZtec)
Rookie Year: 2011
daniel_dsouza has a spectacular aura aboutdaniel_dsouza has a spectacular aura about
The absolute worse case scenario is that your DLink's firmware is corrupted.
Before anyone freaks out, this is the last thing it could be, but it happened to us last season and we had two people spending most to the season trying to figure out what was wrong.
If this is the problem, then the router power light will be flashing (besides the 50 or so seconds it takes to turn on.) You will also not be able to access any settings through a broswer.
To solve this problem go to:http://www.usfirst.org/uploadedFiles...Web_Server.pdf
and you will need this file: http://www.usfirst.org/uploadedFiles...522_fw_121.zip
Which can be found here: http://www.usfirst.org/roboticsprogr...c-kit-of-parts
Good luck,
Daniel D.
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
