Go to Post Mentors are here to guide and explain not to decide and do. - Fe_Will [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
Innovation First International, Inc.
ADVERTISEMENT
Unread 11-28-2011, 09:16 PM
Andrew Lawrence's Avatar
Andrew Lawrence Andrew Lawrence is offline
Learning something new every day
AKA: Andrew Lawrence
FRC #0256 (Robo Rams)
Team Role: Tactician
Rookie Year: 2011
Andrew Lawrence has a reputation beyond reputeAndrew Lawrence has a reputation beyond reputeAndrew Lawrence has a reputation beyond reputeAndrew Lawrence has a reputation beyond reputeAndrew Lawrence has a reputation beyond reputeAndrew Lawrence has a reputation beyond reputeAndrew Lawrence has a reputation beyond reputeAndrew Lawrence has a reputation beyond reputeAndrew Lawrence has a reputation beyond reputeAndrew Lawrence has a reputation beyond reputeAndrew Lawrence has a reputation beyond repute
Send a message via Skype™ to Andrew Lawrence
Bumpers w/pneumatic cylinders
I've had this idea of placing pneumatic cylinders behind our bumpers (see below) for a few possible applications:
1. Shock absorbers: Add a bit of air to small cylinders, small enough to make only a small difference in bumper width from the robot, and use them as shock absorbers for collisions.
2. To use as a "defensive push": Basically, add the cylinders to the the bumpers, and when someone gets a little too close for comfort, we just launch out our bumpers. This could also be used to redirect another robot, or to assist in a pin.
What do you think? Is it legal?
Attachment 11133
NEW website? www.Team256.org
Unread 11-28-2011, 09:20 PM
Duke461's Avatar
Duke461 Duke461 is offline
DotA is awesome!
AKA: Duke, Moneybags, Mad CADder, Ben Carson
FRC #0461 (Westside Boiler Invasion)
Team Role: Leadership
Rookie Year: 2010
Duke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond repute
Send a message via Skype™ to Duke461
Re: Bumpers w/pneumatic cylinders
Someone will probably get a more technical definition soon, but im too lazy .
The first thing you need to remember is that bumper rules change from year to year, so you can't rule out anything yet.
However, using the 2011 rules, I would say illegal, because there would in a sense be "gaps" in you robot. see here.
Hope this helps,
-duke
EDIT: This should help a lot:
The opposite of excellence is good enough.
2012-2013 President; 2011-2012 Vice President
2011-offseason FRC Student Drive Coach; 2010-11, 2011-2012 VEX Drive Coach
2011, 2010-offseason FRC Driver/Operator
2012, 2011-offseason, 2010-offseason FRC Human Player
Find me on: Facebook, Gmail, Twitter, Tumblr, Blogger/Blogspot
Unread 11-28-2011, 09:21 PM
Rookie Year: 2011
Hope this helps,
-duke
And if you make it so the bumpers go over the gap length?
Unread 11-28-2011, 09:24 PM
Duke461's Avatar
DotA is awesome!
Rookie Year: 2010
Im not sure what you mean here, sorry.
Unread 11-28-2011, 09:26 PM
EricH's Avatar
EricH EricH is offline
...has read the 2012 Manual
FRC #0330 (Beach'Bots)
Send a message via Skype™ to EricH
In past years, you'd be moving the bumpers off of the frame perimeter, or expanding the frame perimeter. This would result in gaps in the bumpers' coverage of the frame perimeter, or a violation of mounting rules.
In other words, if the rules don't change on mounting, you're going to be in trouble with the perimeter coverage rules. This is some of what Duke was getting at--<R07-A> in the 2011 rules.
Paths a rules question takes:
Official: Post to Q&A-->GDC reviews-->Official answer posted on Q&A.
Unofficial: Post to CD-->CD views and comments, sometimes using The Manual and interpreting it-->Somebody goes the Official route -->Answer gets posted on CD eventually, as a quote from Q&A.
Which one takes longer for an official ruling? Therefore, which one makes more sense to use?
Unread 11-28-2011, 09:27 PM
Rookie Year: 2011
Me neither, but it's probably possible. I can think of a few ways, but they would be way too advanced. There are other, simpler ways, but I don't know. Just thinking, that's all.
Unread 11-28-2011, 09:29 PM
Duke461's Avatar
DotA is awesome!
Rookie Year: 2010
Yeah i definitely like the concept.
Maybe you could do what the dragonfly robot did, and then on top of that, those appendages could shoot out with pneumatics. That would be awesome.
Unread 11-28-2011, 09:36 PM
Rookie Year: 2011
I like that, but the goal is to avoid hitting opponents above the bumper line. That's why I had the bumpers move, for more bumper on bumper action, and less robot on other robot killing second robot and disqualifying first robot action, if you know what I mean.
Unread 11-28-2011, 09:39 PM
Duke461's Avatar
DotA is awesome!
Rookie Year: 2010
They wouldn't hit above the bumper line. The bumpers, as 3553 did, would be on the ground flush with the real bumpers. Youd simply need some kind of linear slide on the appendages, and the pneumatics would shoot it straight out into the opponents bumper.
Unread 11-28-2011, 09:41 PM
Rookie Year: 2011
I see. I like that! Thanks!
Unread 11-28-2011, 09:52 PM
EricH's Avatar
I would be VERY cautious with using a drop-down active bumper system. If someone tips over while it's active next to them, you're probably going to get warned, possibly carded and penalized. Also, bear in mind the expansion rules, and that you're putting extra weight in there that could probably be better spent elsewhere.
Just some things to keep in mind.
You *might* be able to pull your first option off within the rules, but the "rigid mounting" might get you, at least last year it would have.
Unread 11-28-2011, 09:57 PM
Rookie Year: 2011
I probably should have said this at first, but unless the game next year and manuel give us a distinct advantage, I doubt I'll ever be using it. I just had the idea, and wanted CD's input. From what I'm hearing, the 1st option may be viable, so I'll test that on my own time.
Thanks everyone!
Unread 11-28-2011, 10:16 PM
EricH's Avatar
Thanks everyone!
"Viable" is rather loosely used here, IMO. Under last year's rules, specifically <R07-K>, you'd also need to have the frame perimeter movable to have movable bumpers; that could make life rather "entertaining" with other stuff that needed to attach in that area. You'd also want to pay attention to the pneumatics rules.
Unread 11-28-2011, 10:19 PM
Rookie Year: 2011
Well, I do enjoy "entertaining"!
  #15   Spotlight this post!
Unread 11-29-2011, 06:20 AM
Peter Matteson's Avatar
Peter Matteson Peter Matteson is offline
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Peter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond repute
From the 2011 FRC Manual
K. BUMPERS must attach to the FRAME PERIMETER of the ROBOT with a rigid fastening system to form a tight, robust connection to the main structure/frame (e.g. not attached with Velcro). The attachment system must be designed to withstand vigorous game play. All removable fasteners (e.g. bolts, locking pins, pip-pins, etc.) will be considered part of the BUMPERS.
A movable bumper in not rigidly mounted.
"Dragonfly" got around this rule because technically their additional drop down bumpers were non-functional decorations, not bumpers.
2011 Championship Finalists/Archimedes Division Championships w/ 2016 & 781
2010 Championship Winners/Newton Division Champions
Thank-you 294 & 67
2009 Newton Division Champions w/ 1507 & 121
2008 Archimedes Division Champions w/ 1124 & 1024
2007 Championship Winners/Newton Division Champions w/190, 987 & 177 The Wall of Maroon
2006 Galileo Division Champions w/ 1126 & 201
www.bobcatrobotics.org
"If you can't do it with brains, it won't be done with hours." - Clarence "Kelly" Johnson
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
