Go to Post Seriously, I figured we had until january before we started lawyering things again. - JamesBrown [more]
Team 51   CD-Events   CD-Media   CD-Swap   CD-Spy   FRC-Spy   Unsung FIRST Heroes   WFA
VEXpro
Kettering University
ADVERTISEMENT
Unread 12-03-2011, 04:04 PM
Greg Shaw's Avatar
Greg Shaw Greg Shaw is offline
FRC #3601
Greg Shaw is a jewel in the roughGreg Shaw is a jewel in the roughGreg Shaw is a jewel in the rough
FTC RobotC Programming Problems
I am a mentor of a rookie FTC team. We are using RobotC. We are having the following programming issues. To the best of my knowledge, the most recent drivers and firmware is downloaded and installed. We selected the sample program for basic joystick control.
We know the computer can communicate with the robot because we can run a basic forward movement autonomous program. We know the robot controller can communicate with the computer because when we follow the recommended instructions we get to a screen were there is a picture of our robot controller and whenever we push a button on the actual controller it that button is highlighted by the robot controller that is pictured on the screen.
According to the tutorial, what we see on the screen should be happening on the robot. This is not the case. We can communicate with the computer via the robot controller. We can communicate with the robot via the computer and the NXT. We cannot get the robot controller to control the robot. God bless anyone who can understand what I have just wrote and recommend a solution. I am sure you can tell I am very much a Novice.
Greg Shaw
Lead Mentor
Proud Founding Member FRC Team 3601
Unread 12-03-2011, 07:38 PM
linuxboy linuxboy is offline
AKA: Oliver Graff
FRC #3780 (Robot Unicorn Attack)
linuxboy is a splendid one to beholdlinuxboy is a splendid one to beholdlinuxboy is a splendid one to beholdlinuxboy is a splendid one to beholdlinuxboy is a splendid one to beholdlinuxboy is a splendid one to beholdlinuxboy is a splendid one to behold
Send a message via Skype™ to linuxboy
Re: FTC RobotC Programming Problems
While running the program (little window with a start/stop button and a few others is showing) click on the menu item Robot->Debugger Windows->Joystick Control - FTC
In the new window click teleop: ready, then teleop: running, and you should be good to go!
Oliver
Mac Camera Configuration Tool
Boston Regional 2012 - FRC 3780 - Imagery Award - Dean's List!
Control System Advisor - Championship 2012 - Northeast Utilities Connecticut Regional 2012
2012 Java & Hardware Beta Test
FTAA - Where is Wolcott Offseason 2011 - Mayhem In Merrimack Offseason 2011
Scorekeeper - Bash at the Beach 2011 - River Rage 15
WPI Regional 2011 - FRC 3780 - Rookie All Star Winners - Safety Pins
Field Reset - CTR 2011 - Boston 2011
Unread 12-04-2011, 03:51 PM
Greg Shaw's Avatar
FRC #3601
Thanks for the return message. I followed the steps that you suggested. I still have the same problem--the robot will not move. Despite the fact that the sample program shows up on the NXT and the computer indicates that it is tracking my use of the controller.
Greg Shaw
Lead Mentor
Unread 12-04-2011, 04:07 PM
John_1102's Avatar
John_1102 John_1102 is offline
Poof balls don't fit in your eye!?!
AKA: @j-wizzy @doctorfogarty @mrwizard
FRC #1102 (M'Aiken Magic & 1772 The Brazilian Trailblazers & FTC 3864)
John_1102 has much to be proud ofJohn_1102 has much to be proud ofJohn_1102 has much to be proud ofJohn_1102 has much to be proud ofJohn_1102 has much to be proud ofJohn_1102 has much to be proud ofJohn_1102 has much to be proud ofJohn_1102 has much to be proud of
Send a message via AIM to John_1102 Send a message via Yahoo to John_1102 Send a message via Skype™ to John_1102
Make sure you have in the "Default Tele-Op File" Selector selected the program you are testing otherwise the NXT will not be able to select the correct file.
Also for debugging purposes try opening your NXT Devices window to see if the power being sent to the motors when you move the joysticks is changing.
John Fogarty - University of South Carolina Electrical Engineering 16'
SC FTC FTA - FTC 2013 World Championship Guest Speaker - FRC 1772 Programming/Strategic Mentor
11 Medals, 4 FTC State Championships, 2 FTC Finalists, 1 FRC Finalists, 1 FRC Winning Allaince & 1 FTC World Championship!
"The difficult things we can do immediately, the impossible just takes a little while longer." - ACE
Code:
while(Living){
      Mentor = true;
Unread 12-04-2011, 04:13 PM
Matthew Blake's Avatar
Matthew Blake Matthew Blake is offline
FRC #3481 (Bronc Botz)
Matthew Blake is an unknown quantity at this point
This is most likely your problem. Just make sure in the window that you have the correct program selected, sometimes it will be blank and therefore your NXT Brick will not be running a selected program. (Also make sure you have compiled and downloaded the program you are trying to run to the NXT Brick)
Also, you might want to try a wired connection to the NXT - run a USB cable from the computer to the NXT Brick port. (the cable you would use to update the firmware)
FTC Team 4008: 2009-2012
FTC Team 4602: 2010-2012
FRC Team 3481: 2010-2012
The Chief Delphi Forums are sponsored by Innovation First, Inc.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © Delphi and Pontiac Central High School
