Re: Gear ratios for launcher
0673 @ 12 volts @ 8258 RPM is pulling 68.5 amps and generating 512 watts of waste heat. This seems like it would either trip a breaker or smoke the 0673. Are you sure of your numbers? |
I have seen plenty of shooters on CD this year with the same kind of setup - AM gearbox, FP motor, aiming for about 3 to 5,000 RPMs. If your concern is correct aren't we all in the same boat? If not, any idea where my assumptions have gone wrong? Thanks! |
So we just rechecked wheel speed, and it maxes out at about 3500 RPMs, or 12,991 RPMs motor speed. We measured the voltage across a .01 ohm power resistor and it was about 210 mv. So at max speed it looks like we are drawing about 21 Amps. In-rush current when the wheel starts up peaks out at about 50 Amps for a brief moment.
Now we need to check the motor voltage, maybe that is where the flaw in the applied math is. SW is sending a "1" to the Jaguar, but I guess there is more voltage drop that I expected. Thanks again for the insight. Everything is working ok, at this point it's just a study of the real world numbers we are collecting compared to the expected data based on the motor curves. |
According to the motor curves, An FP-0673 at 11.79 volts (= 12 - 0.210) and 12845 rpm should be drawing about 40 amps. Since you measured the current to be 21 amps, let's use that data instead: According to the motor curves, An FP-0673 drawing 21 amps at 12845 rpm is getting about 9.7 volts. Add the 0.21 drop across the measurement resistor and your Jag is putting out about 9.9 volts. I'd expect it to be a bit higher than that, unless: - your battery is weak - you've got excessive resistance in your wiring or connections - you're running a bunch of other heavy-demand stuff while you're running these tests - the Jag is not putting out 100% PWM - the motor curves are wrong or the motor you have differs substantially from them Quote:
Thanks for sticking with me on this one Ether! :) |
| All times are GMT -5. The time now is 22:35. |
