Re: Low Bar
Re: Low Bar
1. Teams often have trouble doing basic game piece manipulation. Throw in the low bar, and you'll have teams be even worse because now they add in the design constraint of going under the low bar. 2. Doing the low bar means you'll likely have to compromise on some other game objectives. |
Re: Low Bar
I've just seen it as a design challenge so far: how do we fit all the stuff into a compact package? It's been challenging for our team but the process has been positive and productive. Having a low height constraint has the side benefit of preventing other problems (high COG). Hm.
Re: Low Bar
First of all you have to ask if you need to go under the bar in FWD and REV and from which side. The envelope changes significantly if you face your robot toward the opponent's tower or toward your own because (thanks FIRST) the bar is not in the middle of the outer works. A lot depends on your wheel base and wheel diameters and such but (SPOILERS) there is a V out in front of (and behind of) your robot that is not even close to 14 inches from the "ground plane" (i.e. the plane that your robot drives on if it were a flat floor). I don't have the CAD pulled up but I think for our particular chassis parameters, the base of the V shaped "keep out zones" comes close to the top of our bumper. SO... really if you have some boulder collector device you plan on folding out in front of your robot while it's doing the limbo, you really really really need to be sure that you can limbo in the real world not just in your minds. Word to the wise. Dr. Joe J. P.S. Getting your boulder mechanism hooked on the limbo bar counts as a Tortuga. I'm just saying... |
Re: Low Bar
Re: Low Bar
This is what I see the advantages and disadvantages of being against a defender.
Cons: 1. Your cycle time when shooting is increased. depending on the robot matchup (faster vs slower, taller vs shorter) this could be significant. 2. Your potential to challenge the tower for the extra point at the end of the match could be at risk. 3. You can have your boulder stolen from you in a race to pick up a deflected ball. This would be a significant time loss. Pros: 1. Unless the defender leaves to accomplish tasks periodically it isn't contributing to its team's ability to meet the requirements to gain ranking points (barring W-L points). 2. A defender is scoring 0 boulders while defending. Assuming all robots have equal offensive scoring capabilities (a stretch, I know but for the sake of argument) a 3 robot offensive is still going to push out more points through goals unless said defender can impede the progress of more than one robot simultaneously and do it well. 2 unimpeded robots on the enemy alliance are not going to outscore 2 unimpeded robots on your alliance plus one impeded robot. On that note, if anyone has some good footage of defensive robots impeding multiple robots during an FRC game where multiple robots can score at the same time (much like this year's challenge) I'm looking for them! I do think there will be some strong defenders and I need to convince the rest of my team they exist. Now on the topic of "low robots will always be shut down by tall robots" I don't think that will be the case because: 1. You can close the distance between yourself and the tower where a robot can't maneuver in between yourself and the goal. Stopping you from getting to that point is difficult since the defender would need to give you enough space to start in their courtyard to not incur a foul when you are traversing the outer works. 2. Trajectory is key. If you arc your shot you can shoot over a tall robot. As long as you're not shooting from the front edge of your robot you have wiggle room to arc it. |
Re: Low Bar
Re: Low Bar
Re: Low Bar
Re: Low Bar
We are doing the low bar and so far haven't ran into any major issues. I think it's accessible to a lot of teams with a little planning, but it definitely requires some thought & testing to package everything well. |
Re: Low Bar
Re: Low Bar
I do think that if nearly all robots are short and specialize in going under the bar to retrieve balls from the secret passage that there will be room for robots that specialize in other aspects of the game to excel as they will likely have more complimentary alliances. |
Re: Low Bar
I think there are some inherent advantages to being "compact" (generally synonymous with short) this year in addition to getting under the low bar. In fact, the low bar height is just a convenient target value for "compactness". This field is one big fatigue test rig. In order to survive and function the entire season, your robot will need to be robust. The fewer moving parts, deployable mechanisms, lanky appendages, etc., the better you will be after the umpteenth crossing of the Group B & D defenses. A robot that can collect a boulder, cross a defense, and shoot a high goal without moving anything in the shooter assembly is more likely to survive continued contact with this game. Shooting from the batter requires a bit more driving, but it is a semi-protected shot that can be aimed by driving into a couple of fixed field elements (the tower and the driver station wall). Being able to go under the low bar isn't critical to this approach, but it is a good fit. Scaling the tower is another matter... |
Re: Low Bar
Re: Low Bar
Speaking of which, has any team ever made a trapezoid robot? |
| All times are GMT -5. The time now is 07:13. |
