Re: HELP NEEDED: Solenoids not firing
We will try to increase the pulse time once we unbag our robot. Thanks for the responses! |
Problem solved.
From the data sheet: • 2-position, single solenoid normally closed spring return; Since it is normally closed, when the solenoid is not powered, the spring returns it to the closed position. These solenoids need you to hold the the 24V on the coil, not pulse it. To be clear, you have the ones with only one black wart with wires, correct? |
Update:
We tried working backwards on our other identical robot. We tested the voltage going to the solenoids forwards and reverse and it actuated with 24v. With only 12v the solenoids light up, but don't actuate. The pulse in code is 0.25 seconds and works perfectly fine on this robot (the code is identical for both). On our competition bot (the one that doesn't work) we are going to oscope and multimeter the signal from the PCM to solenoid and if it is correct (24v and 0.25sec pulse) we will swap out the solenoid and if it is not correct we will swap out the PCM. |
On the single coil solenoid that you have, the spring holds the position to normally closed (lets call it A) and to switch to open (B) you energize the coil. You need to hold the coil energized for the entire time you want the solenoid open, because the spring returns it to normally closed whenever the coil is not energized. If you don't pulse it, but hold the value you should be fine. The manual button activivation works because the data sheet specifically says it latches. Good luck at your competitions. |
If you have single coil solenoids, you should not pulse the coil - it returns to the normally close position when the coil is not energized. |
Thanks for all the suggestions everyone! We fixed the problem by replacing the pcm.
| All times are GMT -5. The time now is 11:53. |
